How do I power an LED light strip?
Hello,
I just purchased an LED light strip from Amazon:
Triangle Bulbs 3528-IP65-White-60L Pure White LED Strip Light, Waterproof LED Flexible Light Strip 12V with 300 SMD LED
12 VDC Super bright Waterproof Cool White 3528 SMD LED strip
    Length:16.4 ft./5 Meter 300 LED lights per reel. Allowable cut every 3 LED lights
    Easy and flexible installation. Ideal for home and business lighting decoration.
    Comes with 3M adhesive sticky backing
    High brightness, wide angle LED chip. Low power consumption - Only 4.8W/m LIfe: 50,000 hours
I already have a 12V DC 2A battery pack. (it holds 8 AA Batteries).
What else do I need to complete the circuit?  I am thinking I need some sort of on/off switch, but have no idea what I need to buy.
Thanks!!!!
iceng2 years ago
You are doing well.
Based on your batteries find any switch that specifies it can handle 4 or more amps DC, don't be concerned about switch voltage. Radio Shack carries switches.
To verify the select switch, tell us the length of your strip ?
KaleiS (author)  iceng2 years ago
thanks iceng! The total length of approx. 16ft is too long. I will be cutting it down to about 2 ft for the project display I am creating. Doing the math, because I don't yet have the strips, it will run about 35-40 LED's. I do not know how to figure out amps, mAh, or other electric lingo. Mpilchfamily mentioned not needing a switch and I am thinking of using that advice. Do you know if with following that advice I will need to solder anything? I would like to keep this simple because of my low tech skills.
iceng KaleiS2 years ago
Sure a switch is only a convenience, but you will need to take out a battery or interrupt the current to turn it off.
Your strip needs 4.8 watts per meter close to 2 feet.
Watts is the product of volts times amps. We know 4.8W and 12V.
Amps = 4.8/12 =o.4A or 400 milliamperes . So your 2' strip will use less then four tenths of an ampere.
Now Alkaline AA batteries are rated at 2.12 Amp hours of energy.
So your display should last 2.12 / 0.4 = 5.3h over five hours.....
iceng iceng2 years ago
Thank you :)
Be sure when you connect to the strip to observe polarity !
Battery + to strip + always the RED wire and
Black wire - to -.......
KaleiS (author) 2 years ago
thank you to both iceng and mpilchfamily. Both your answers were equally helpful and gave me the confidence I need to complete my project. Mahalo nui loa! Hawaiian for thank you very much.
KaleiS (author)  KaleiS2 years ago
final comment. I purchased a switch from radio shack and will complete my project with the led strip, switch, 12v DC AA 8 battery pack.
StephenJ261 year ago
How many of these 16 ft light strips can I connect together on one 12v power supply?
Shouldn't NEED to buy anything. Connect it to the battery and it's on, remove it and it's off. If you want to add a switch then do so. Nothing more too it really.
KaleiS (author)  mpilchfamily2 years ago
thanks mpilchfamily! I like knowing that I don't need the switch and may just do that. I was worried that there was something I was missing. This is my first time connecting LEDs. This is a one time temporary project that will be lit for 1hour. I have 12v DC plugs too, but like the portability off the battery pack.
*of
