How do I power my 50 red 3-watt LED's and my 20 blue 3-watt LED's without using resistors to make a panel?? PLEASE HELP
I am trying to build a grow light with 50 - 3 watt Red LED lights and 20 - 3 watt BLUE LED lights. The total power consumed would be 210 watts.
Specs for Blue lights:
DC Forward Voltage (VF): 3.2 Vdc ~ 4.0 Vdc
DC Forward Current (IF): Typ 650mA
Specs for Red lights:
DC Forward Voltage (VF): 2.0 ~ 2.8 Vdc
I know a lot of things on the internet call for resistors but for this project, resistors would give off far too much heat. I know that an LED driver can be used in place of the resistors, but I don't know anything about voltage or amps.
I have found a few 200W LED drivers that connect to an outlet and convert the power to a 24V DC, which is usable by LED's.
I just don't know if that's all I have to do: connect the driver to the LEDs in a parallel circuit.
Actually, I don't know how to find the Constant Current Module that I need at all.
PLEASE HELP ME!
15
answers
Answer it!
Next rectify the AC 120V Line with a 220 uF electrolytic capacitor for 170 VDC min...
Now add a 48 V 750ma transformer in series with the AC line and this rectifies to 268 VDC.max.
Add a 100 ohm series resistor 50 watt (or 10 5watt 10 ohm in series ) if the LED fwd is 200V Low.
if the LEDs fwd is 256V high, add a 12 ohm resistor 5 watt in series..
If I did this correctly you need a 300V 2A DC Bridge, a Radio-Shack 120/48V 750ma transformer, one power resistor, all your LEDs, and heatsinks, a 220uF 300VDC capacitor, and a 1amp slow blow fuse to grow your plants from line power.
I would check the current flow and adjust to the desired 650 ma by changing the resistance one resistance.
Steve
Look online for "200W LED driver" gets quite a few hits.
Steve
So If I put the driver on a panel, connect all of the LEDs in a parallel circuit, will the lights be at their optimal power? The only thing I know about is Watts. I was just going on the thought that if I have 70 3-watt leds, then I need a 200-watt driver.
Do I need any resistors or any other type of converter to connect the driver and the LEDs to the power outlet? The outlet is usually 120v, right? I don't want to blow all the diodes when I plug it up or have the driver overheat and have a big mess.
If possible, someone who has a few minutes to spare, could anyone explain or draw out a simple diagram of how I'd need to wire everything together?
Sorry I'm so helpless... lol
You need a product like
http://www.dealextreme.com/p/3-0a-100w-power-constant-current-source-led-driver-85-265v-47306 100 watt
and/or
http://www.dealextreme.com/p/1-6a-50w-power-constant-current-source-led-driver-85-265v-47304 50 watt
and/or
http://www.dealextreme.com/p/1-7a-60w-power-constant-current-source-led-driver-85-265v-47305 60
There are many many options for drivers, but two of these will power your array quite happily.
Also consider - you'll need to bolt your leds to a MASSIVE heatsink, or a small heatsink individually to prevent the aforementioned fire.
You need some combination of series and parallel to absorb that power as evenly as possible.
Since there's an uneven number of red vs blue lights, you probably want dissimilar drivers...to match the totals of each and keep things simple.
"Specs for Blue lights: x20
Let`s say 3.5 volts each as a safe number
Total = 3.5 x .65 x 20 = 45.5
Specs for Red lights: x50 <<DC Forward Voltage (VF): 2.0 ~ 2.8 Vdc
Let`s say 2.5v to be in the middle again...
Total = 2.5 x 0.65 x 50 = 97.5 watts
I'm trying to do the maths, and they don't add up - can you confirm your numbers? Every bit of data you have helps.
The usual thing is a piece of Extruded aluminium heatsink.
Red (50 diodes)
Forward Voltage (1.8-2.4)
Wavelength if 750mA (620-630)
MCD if 750mA (160,000-200,000)
Reverse Current(uA) Vr=5V ---> Max (10)
Blue (20 diodes)
Forward Voltage (3-3.2)
Wavelength if 750mA (460-465)
MCD if 750mA (250,000-270,000)
Does that help?
It explains some of the math, and a few solutions.
As for driving 50 of them, you still need a big driver, but this helps it make sense.
Blue 3.2*.75 = 2.4 watts.
I'd be asking the seller for an official datasheet for those. Often the numbers are inflated to make the product look better and you might burn them out driving them at those currents. It won't hurt them to be under-driven however, in fact it's generally safer.
So what should I do to power them? I e-mailed the ebay company and they guarantee to get back with you in under 2 business days; I asked for the datasheet.
How much power should I feed them if the values you have are correct?
Thank both of you guys for helping me, btw.
They might be under-driving them to make them last longer. Trouble is, most constant current supplies can only work within a 'window' of voltages to ensure the correct amperage is reached. When you get a reply, let us know, we'll be happy to help (or someone will)
What do you think?
Electrical-Optical Characteristic (Ta=25oC)
Item Conditions Min. Typ. Max.. Unit
Forward Voltage VF If=700mA 1.8 2.0 2.2 V
Dominant Wavelength λp IF=700mA 625 / 635 nm
Luminous Intensity IV IF=700mA / 85 100 lm
50% Power Angle 2θ1/2 IF=700mA / 140 / degree
Note:
Absolute maximum ratings Ta=25
Tolerance of measurement of forward voltage±0.1V
Tolerance of measurement of peak Wavelength ±100K
Tolernce of measurement of luminous intensity±15%
Absolute Maximum Ratings (Ta = 25oC)
Item Symbol Absolute Max. Rating Unit
Power Dissipation PD 3000 mW
Forward Current (DC) IF 700 mA
Peak Forward Current IFP 1000 mA
Reverse Voltage VR 10 V
Operation Temperature Topr -40~100oC /
Storage Temperature Tstg -40~120oC /
Lead Soldering Temperature Tsol Max. 260oC for 5 sec.
