loading
How do I repair my Philips Sonicare toothbrush? ?
I can see inside but, cannot figure out how the vibrations were generated, before the thing broke. Now, it only delivers a sonic whine, and doesn't jiggle the brush head.?
afro53 (author) 7 years ago
Voila! I know why my sonicare is just whining, instead of whitening. Hopefully you can see the uploaded image. On the left is my broken original and on the left is a similar, working, replacement. In the middle is the offending item. As noted to me on this site, the toothbrush must've been dropped, causing the shaft to snap. The shaft is a precision-made, angled stem, with a collar at each end. The collars are screwed to the rest of the assembly at either end, and held taught. At the bottom of the shaft you can see a metal block, in the middle of the photo. On the replacement unit, this is suspended about 1mm above the linear motors. At least, I was told that they are motors but, I think that they are strong electromagnets. By alternating the motors, the assembly is made to vibrate wildly, and move the brush head. In my broken unit, the shaft (which you can see is snapped at an angle) and metal block have been able to drop onto the magnets. No more vibrations, no more toothbrush. It is not a repairable item. These things should be marked fragile but, it's quite clever how they work. FYI I told that the Sonex toothbrush uses ultrasonics to remove plaque. I tried one once - it hurt like hell (imagine punching your own gums) but did a great job of cleaning.
ChristineW827 months ago
Hi when I try to replace my new toothbrush head it doesn't "snap" in it feels really loose. the metal part seems to wiggle more. I notice now when I brush i the bristles don't vibrate but I can hear it turn on. I believe its because the replacement inst connecting properly with the base
I have the Sonicare Series 900 does anyone have any recommendations to repair? i went to www.fixmysonicare.com and the site doesn't work anymore.
MichaelC272 years ago
do the magnets have to be in a certain position? I took the head off to clean the inside and pulled the magnets off and when I put them back on it just hums..
aw762 years ago
proceed with caution at www.fixmysonicare.com
in fairness, this guy did repair my broken toothbrush. However, when I got it back, it seems as if the battery is not be the one i sent it with, as it no longer holds charge for more than one brushing, whereas I used to go for about a week without charging before I sent it to him. I tried contacting him about this a couple times with no response. He had replied to my emails when I was in the process of shipping it out to him. Very disappointing customer service after the fact!
Technically, my toothbrush does work if i leave it plugged in around the clock (not very energy efficient though :( )
so, cheers and jeers for this sketchy bugger.
ralph.kim12 years ago
My new replacement heads are very loud and do appear and sound like there is something in them are very loose. How can these be replaced?
I've used this toothbrush for over 5 years now and have had no problem. This is the first time this has hppened. I cannot continue using this replacement brush with this sound. Please tell me what to do.
Thanks,
Ralph
PBJIV2 years ago
website www.fixmysonicare.com is no longer up. Does anyone have an address or phone number? When I checked this website last, they could repair the broken shaft problem. That is what is wrong with mine.
Or if anyone knows where to get parts (other than batteries) for a HX6930, that would be helpful too.
ansher3 years ago
I had same issue with the metal shaft and found guy who does that kind of repair for only $25 . His site is www.fixmysonicare.com . So far so good.
Thanks SOOO much for posting this. I sent my toothbrush off and just got it back yesterday good as new! So glad I didn't go out and buy a new one! Mine is at least 4 years old and working like it did when I first got it. I can also recommend this site: http://www.fixmysonicare.com/page1.php
bfees3 years ago
My Sonicare is 6 months old. It continually blinks. When off the charger it blinks very fast. On the charger blinks as normal but NEVER STOPS blinking. Still works but don't know why it won't stop blinking.
CRDBASS3 years ago
Not sure I have seen a solution to this problem, but I am on my third Sonicare, all three dying the same death... CAN THEY BE FIXED... I've skimmed these answers and have not seen a solution... appreciate any input...
ansher CRDBASS3 years ago
See my above comment. YES THEY CAN !
Sandisk1duo8 years ago
try guing the little sonic motor inside the casing
guing should be 'gluing'
afro53 (author)  Sandisk1duo7 years ago
However you spell it, you have to understand it, first. What would I glue it to? As I say, it makes the sonic whine but, this isn't converted to brush head action. I think the fault is with the mechanics at the head end but, I can't follow through how it might work.
mmark666 afro534 years ago
I know this is an quite old thread, but my Sonicare suffered exactly the same failure after a few weeks of usage. You could here a faint hum, but no sonic movement. I took it apart and found the same broken connector piece you showed in your picture. This connector piece (you called it angle stem) seems to have a weak spot since mine broke at the exact same position as far as I can tell. But I don't agree with your assumption that we can't fix it. I'll try to make a new stem and report back if I was able to fix it.
If other people observe the same failure mode, please report!
BTW: it's not really ultrasonic: I measured the frequency with my scope and it's exactly 1 kHz, far from ultrasonic...
afro53 (author)  mmark6664 years ago
Yes, Please, fix it!
I am on my 2nd or 3rd but, my girlfriend has dropped her Sonicare, and broke it! Now it sounds like a tractor, and doesn't brush teeth!
The Sonicare works by vibrating the shaft at high speed. The shaft is a precision piece and, when vibrating at several hundred cycles per second, it is constantly in a stressed state. So, when you drop it whilst it is in use, the shaft almost 'has' to break.
A precision replacement shaft would cure it, every time. I just don't have the resources but, it is just a piece of pressed steel, cut and shaped.
I think that you could sell such a replacement part, or offer a repair service, once you have a access to copies of the part.
Arx afro534 years ago
it only vibrates about 16-17 times per second. I don't remember ever dropping mine. I think it's just metal fatigue.
Arx mmark6664 years ago
Wow. mine is broken the same, only instead of breaking all the way across the shaft at a 45 degree angle, mine is broken in a perfect V that lines up perfectly with the crease in the middle. It looks almost as if it was cut that way.
I've never dropped mine, so presumably it's metal fatigue. I've had it about a year. It got kind of loud a couple weeks ago, and then a few days later quit working, making only a quiet hum.
Did you manage to repair yours?
Thanks for posting these pics. I thought my battery was shot, and replaced it only to have the same issue. Then I noticed the magnets were stuck to the face of the coil. Disassembled and I had the exact same problem. The metal piece which transfers the vibration from the magnets in the electric field to the brush head, had broken at the exact same angle, and the same length. The brush was never dropped. It's a shame they don't sell that part, as otherwise the toothbrush is in great shape. Sure looks like a design flaw to me.
turn in on while it's disassembled, see if the motor moves
TL20124 years ago
i have a similar problem except nothing is broken. if you push too hard as you are brushing, the vibration weakens till the point its completely stopped in the brush head, but not the handle. I opened the whole thing up, can't find anything wrong with it, except maybe the rubber piece is a bit loose, and i can reproduce the problem by pushing the tip to certain direction. any fix ideas?
jining4 years ago
My toothbrush broke in this same way, same place of fracture. Sonicare refuses to send me this small metal piece because I voided warranty when I opened it. Did you ever find a solution?
eric m6 years ago
This is a linear motor? huh?
 Great inputs - but how do you get them apart? I have an HX7500. It was put in a drawer for a few months in working condition but without the charger hooked up, and now it won't charge. I have heard you can give NiCads a "quick high current shot" to get them going again, and want to try it here, but can't get it open! Thank you!
afro53 (author)  glennoccupant6 years ago
 The base twists out and off, if you use a screwdriver - the thicker, the better, in order to minimise damage to this fairly soft plastic of the base.
I found a guy on eBay who fixed mine in a week (first class mail) for $25. I would have bought a new one, but I had three working brush-heads that wouldn't fit the new handles. I took a chance and I am glad I did. Mine was the classic 4700 model with quadpacer, and it works as good as new. Look for "Sonic Repair". Great e-business man -- I even sent him my first dead handle for him to recycle into spare parts, and he overpaid me for the postage!
afro53 (author)  stress_guy_53-307 years ago
I could find no such e-bay vendor.
frollard8 years ago
Sonicare toothbrushes dont have a motor 'per say' as there is no direct linkage from the motor coils to the brushhead magnets. They have a linear motor. There are 2 small VERY strong rare earth magnets (painted black) on the brush head replacement. The high pitch whine is the coil of the 'motor' reversing polarity very quickly. I've had the magnets come off my brushhead before. Once they're off they need putting back in place, and add some glue because they're under a LOT of strain in there.
afro53 (author)  frollard7 years ago
My brush heads have a silver disc and have no painted black parts. The rar earth magnets make some sense but, not entirely. I also have three replacement heads and, still nothing happens, bar the noise. If it helps, the motor does seem detachable from th e battery section.
frollard afro537 years ago
whoa - thats different from the stuff I've seen. I guess you have the 'advanced' version...correct?
I'm not sure if it's advanced but, the charger kit included the UV 'bath' for the brush head. Top dollar, if it wasn't for eBay.
110100101108 years ago
ouch ! just get a brush that does not have complex mechanics and circuits
when you drop 50-200 dollars for a toothbrush, you would rather not just chuck it :D
afro53 (author)  110100101107 years ago
That doesn't repair the one that you already have - you're not reading the question properly.
