How do I replace the mini lights on my Christmas tree with LEDs?
Mini lights get too hot, but my tree is per-wired and re-wring would be too much trouble.
Ay luck would be great.
5
answers
Answer it!
As a test I swapped out one lights for a led, the string came back on, but the led did not light.
If it was a normal one you could probably have burned it instantly because you did not add a limiting resistor.
Plus, if this works depends on your light string if this works or not. I doubt that they are all designed the same way. That means you have to find out the voltage on the bulb sockets and if it is AC or DC going through.
When you figured that out you can search for LEDs that would fit your string and calculate the needed resistor values (you can use this wizard here: http://led.linear1.org/led.wiz).
But I assume it would be faster and way more inexpensive if you would just cut off the old string and replace it.
