loading
How do I share 2 printers on a single ethernet jack that is hooked to an internal network?
Every office in my building has an ethernet jack. One room houses a HP laser printer that is currently utilizing the single jack. I'm putting a wide format color inkjet printer in the same room. I need to connect it to the internal network for others to share this printer as they do with the laser printer. There is a hub located in another part of the building that connects this intranet. To add my new printer is it a matter of plugging another hub into the existing jack and then plugging the two printers into the hub or is there another way? Thanks, Chas.
Chas.7 years ago
Thanks to all that posted a solution. A small switch it shall be. Chas.
frollard7 years ago
A hub or a switch will do - a switch is just a hub with more brains. A hub takes all packets in on any port, and spits them out on all other ports. A switch reads the address info and only forwards packets to where they need to go. Hubs are cheaper - switches are 'better' - but if you're just using it for sharing to printers, hubs are excellent for the job.
NachoMahma7 years ago
. Unless the printers are going to see a lot of traffic, a simple hub should work. You may want to step up to a switch. A router would be overkill.
Can you still buy hubs?? With a mini-switch around 15 quid (20 bucks), why use anything else?
AndyGadget7 years ago
The clean and simple way is to just put in a small 5 or 8 port network switch and take the printers off that. An alternative would be to use a pair of CAT5 doublers at the main hub and room port to give you 2 connections out of the port, but this is a bit of a 'quick and dirty' method which would work, but is not strictly to ethernet spec.
