How do I stop our bigger dog from eating our smaller dogs food? ?
8
answers
Answer it!
the bigger dog might like the location of the chihuahuas food bowl better than its own, i have two dogs that just share the food bowl, perhaps your dogs will like it better this way.
The only other trick I've used is when I watch my friend's bichon, I put his food under the chair, that only really works if I'm around, but it is protected enough that my dog goes for her bowl first and my friend's dog gets a fighting chance at his own bowl.
You could try training both dogs not to eat anything until given permission to do so -- which some vets used to recommend as being both a good training exercise and possibly useful in preventing the dog from eating something that might hurt it. That's not going to be fast or easy, and it requires that you be absolutely consistent about enforcing the rule and reinforcing the training. How hard are YOU willing to work?
Suggestion: Ask your vet. This situation must happen all the time when there are adult dogs and puppies in the same household, and I'm sure there are standard techniques for dealing with it.
One other possibility, which might not work: Give both dogs identical bowls, sized so the chihuahua is comfortable with them. Then if the big guy goes after the small one's bowl, the smaller dog can easily jump to the bigger dog's bowl. If the bowls are kept a few feet apart, trying to claim them both would be impractical... so while this might yield some chasing back and forth, it should mean that both get to eat. Unless the big dog finishes his bowl and _then_ goes after the second serving, which some might... though the chihuahua can counter that to some degree by eating quickly.
Or feed them in separate rooms. That's what I do. I don't leave food out all day.
You can try to train the big dog but he'll eventually eat all the food when you aren't looking. Labs want to eat everything and then some.
+1 easy solution. since they're nowhere near the same size, although the OP will need to make sure the caged area is deeper than the lab mic can stick his head in and heavy enough or well secured enough he can't tip it over. Dogs are a bit like humans...if there's a way they'll find it.
- Feed the dogs separately and only twice daily.
- Electronics and hardware covering the Chihuahua's food opening to any number devices in the dog collar presence and more devious.
- Size discrimination giving and denying access like a half swinging door which human can lock but let the small dog through as we do.
