How do I sweep a chimney?
I've got a basement and main floor fireplace, both share the same chimney and both are the original brick fireplaces built into the house in in I'm guessing the 50's or 60's
The instructables hive mind knows just about everything, so what can you tell me?
answers
Answer it!
Mix your high temp cement to the consistency of cake batter. Use a masonry bag and wet the area first, it need not be sopping wet. Apply only about 1/4 inch thick at a time. this is very important or it will not cure right. Let cure for at least 30 minutes before applying another layer.
If your fireblock needs replacing take out only the ones that are damaged..such as very crumbely or flaking in large flakes. If they are damaged it should not be hard to remove them. Make sure the new brick is wet before using grout. Check to make sure moisture is not getting inside chimney or firebox. I good indicator is if your damper frame, wich is secured into the inside of the flume is rusted badly or not.
Soemtimes it is just poor chimney desighn. But if you have had the house awhile and know that no repairs have ben done before then its just a matter of maintanance.
I have noticed that very old houses on the east coast seldom have problems like the west does. Saying fireplaces and chimneys were more robust and carefuly crafted would be an understatment. Since your chimney goes all the way down to the basement look on the bottom wall of the chimeny and somewhere should be a cleanout hatch. There should be one in your fireplace bottom also to sweep ashes in and then clean from the basement. There are other web sites that will tell you all of this with pics wich I do not have to offer. Its not very hard except the masonry repair part if you have not done any before. It is so critical that you get it right i would say get a proffesional and bite the bullet and pay up until you know exactly what to do.
Nothing is worth having your house burn down.
