How do I turn tap lights into blinking led lights?
Please help! I found a Youtube video of a deadmau5 head with led lights from rave gloves moded to regular tap lights. Only the user who made the head doesn't tell you how he did it. Does anyone know how it's done? Thanks for you help. Here is the link: http://www.youtube.com/watch?v=I809lwRceb4?
Aug 9, 2011. 11:40 AMorksecurity says:
Uhm... I'm not sure what question you're asking.
There are two separate lighting systems there. One is the "eyes", which are the "tap lights" -- just a push-on/push-off switch controlling a light. The other is the outlines, which appear to electroluminescent wire controlled by some form of blinker or color-organ circuit.
Aug 9, 2011. 9:07 AMsshuggi says:
I have a pretty decent idea of how it could be done. If you want to make it, you would need to know a bit about circuitry. Do the words opamps and 555 timers mean anything to you? Because, I'm feeling that's how it's done.
Aug 9, 2011. 11:42 AMsshuggi says:
Ahh, he really didn't "make" anything new. He just got some other product with flashing lights and adapted them to the helmet. To answer your question about the tap lights. You only need to do a quick rewiring. I attached a picture of the basic outline of how it's done. All you would have to do is frost the inside of the tap light with a quick spurt of white spray paint, rewire the lights with the tap light switch, and then put the LED's inside the light.
Aug 9, 2011. 12:29 PMsshuggi says:
No problem, if your lights and stuff aren't as simple as I made them out to be, you can just send me a message and we can work it out.
Aug 9, 2011. 9:11 AMyokozuna says:
I can't watch your link, but I'm guessing it's almost as simple as LED throwies, but modified so that the circuit only completes when weight is applied.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
