How do i add a button to my arduino code so when i press it it will change to another code?
so i have my program and it is a 4 led chaser and i want to push a button and and make it do a different pattern this is my code i works
int pinled1 = 12;
int pinled2 = 11;
int pinled3 = 10;
int pinled4 = 9;
int tim = 50;
void setup()
pinMode(pinled1, OUTPUT);
delay(50);
pinMode(pinled2, OUTPUT);
delay(50);
pinMode(pinled3, OUTPUT);
delay(50);
pinMode(pinled4, OUTPUT);
delay(50);
void loop()
digitalWrite(pinled1, LOW);
delay(tim);
digitalWrite(pinled1, HIGH);
delay(tim);
digitalWrite(pinled2, LOW);
delay(tim);
digitalWrite(pinled2, HIGH);
delay(tim);
digitalWrite(pinled3, LOW);
delay(tim);
digitalWrite(pinled3, HIGH);
delay(tim);
digitalWrite(pinled4, LOW);
delay(tim);
digitalWrite(pinled4, HIGH);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
You could make each pattern in a "if" statement, like lemonie said, and also have the led pattern inside a "while" statement so that it will keep repeating until the other button is pressed. the code would look something like this:
int pinled1 = 12;
int pinled2 = 11;
int pinled3 = 10;
int pinled4 = 9;
int button1 = whatever pin you want it on;
int button2 = whatever pin you want it on;
int buttonstate1 = 0; // this variable will change
int buttonstate2 = 0; // this variable will change
int tim = 50;
void setup()
delay(50);
delay(50);
delay(50);
delay(50);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
void loop()
buttonstate1 = digitalread(button1);
buttonstate2 = digitalread(button2);
if (buttonstate1 == HIGH){
while(buttonstate2 ==  LOW)
//put your led pattern here
else if (buttonstate2 == HIGH){
while(buttonstate1 == LOW)
//put second led pattern here
You could shorten it up by making a "check buttons" subroutine.  Also, why did you put delays after you set the pins to input or out put?  The code may not be completely right(a few semi-colons or brackets missing)
if you have any other questions, just let me know
MACKattacksnipe (author)  JaredsProjects7 years ago
try it if you have a arduino try it it works i know its weird but it works
I don't have an arduino available right now, but I might try in when I get another one.
Thank you  for select my answer for best answer!
oh i just got mine but you seem to know the language well
what if i only want 1 button
lemonie7 years ago
Some king of "if" statement?
L
