How do i make a capacitor charger circuit?
I knew what to look for, so i found it; the transformer for the capacitor charging circuit and the big cap for it. I unsoldered the transformer piece, cut the wires from the cap (it was not mounted on the board), and unsoldered the flash which had not 2 but 3 wires coming from it. one was yellow, one was green, and one was black and was attached to the deflector behind the flash. the black wire was connected to a small black piece that looked a lot like the charger transformer but only had two active pins instead of four. im not sure what it is for, i think it is a self resetting fuse, incase the camera short cicuits, but im not sure. any insight on that would also be helpful.
Back onto the subject, i would like to know what i need (other than the yellow transformer piece) to make the charger circuit. I have heard there was a transistor, would it be NPN or PNP?
there was also a diode, i am guessing one of the black ones, but is there anything else? i have those three things if that is all i need, but how do i solder it all together?
thanks in advance,
z247
PS: the yellow transformer has only 4 pins that actually do anything, one is between two on one side and is only for support. either that or i accidentaly broke it.
9
answers
Answer it!
http://www.talkingelectronics.com/projects/XenonFlasher/XenonFlasher.html
to be helpful.
I was going to say something about the foolishness of taking apart a perfectly good, working, circuit, you know... without taking, notes, pictures, making a diagram to show how to put it back together again... but I then decided that would be unkind.
The link above will hopefully give you some clues as to how to put your charger circuit back together again, or how to build a new one.
I will check out the links you both posted though.
You had a charging circuit hooked-up to a cap', but you took it apart and now you want to know how to put it back together?
I'd look at coil gun instructables first.
http://www.instructables.com/tag/?sort=none&limit%3Atype%3Aid=on&q=coil+gun
L
so in short, it was on a big set of circuit boards that had to be hooked together to work.
i wanted it to be more smaller form-factor, so it would fit in the shell for my gun that i plan to use.
Yes, I know them. How to reconnect the bits is on the PCB - trace the copper-tracks and you'll know what goes where.
L
this is quite confusing!
i looked at the Coilgun handgun instructable, the one tha won a competition, and in one of the steps a circuit diagram is shown, using the circuit board at least.
im not sure what type of transistor is in that part though, i don't quite understand the circuit from the way that it is.
i might have to go to the local thrift store and find some film cameras, that way i can figure this out. luckily, they sell them a dime a dozen, there are millions there, but i cnt get there on a sunday.
if i could just find a schematic of just that part of the circuit, i could make this.
http://www.talkingelectronics.com/projects/FluorescentInverter/FluorescentInverter.html
L
