How do i take a 5 speed transmission out of gear without the gear shift?
caarntedd6 years ago
If the box is the type that has everything internal (no external 'levers' on the side) then you should be able to stick a screwdriver in the hole in the top, (I'm assuming the shifter is completely gone), and shift it into neutral. Just shift stuff around until you get it. Is the box still in a car? Then depress the clutch, or rock the car back and forth without the clutch (brakes off) as you try and shift. Beware of the car rolling away as it goes into neutral. If the box is out of the car twist the output shaft back and forth while you try and shift.
NachoMahma6 years ago
. There are probably three levers on the side of the transmission. Use those to shift to whichever gear you want.
Kiteman6 years ago
Press the clutch.
Yeah, that's about it. Unless you've got a fly-by-wire system and have software which will talk to the car's computer on that level.
