loading
How do we build a Manual water pump
Our kids and  I want to build a water pump, for a water science project / play exercise.
i want to provide them with lots of pipes and things to build water "contraption "
We need a manual  / foot pump - ....How do we build a water pump and with what items do we need?
We have access to a certain amount of junk, but happy to by new items and have access (shops) to almost anything that would be needed.
I do not want to use electrficity , batteries or compressed air to drive the pump - but foot power....Any idea's thx
Irfaan in Riyadh and Cape Town
chuangt2u5 years ago
We just built a water pump. 2 hours to build and test, and meets your materials requirements... could easily be adapted to foot power using a treadle.
https://www.instructables.com/id/Coil-Pump/
n1cod3mus7 years ago
i just wrote an instructable to make a hand pump, it works, i hope it helps
www.instructables.com/id/Homemade-WaterAir-hand-pump/
jovenhatsjr7 years ago
try browsing @ tv.links and look for EMAS pump
Re-design7 years ago
Build an Archimedes screw.  You could make if foot powered by hooking it to a bicycle but I'd just put a hand crank on it and us it that way.
Make it using an 8" pvc drain pipe and 2" clear tubing and they can see how it works by trapping the water and bringing it up.
http://images.google.com/images?q=archimedes+screw&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=9pXhSqDUPMqW8Aats_z6AQ&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CB8QsAQwAw
Koosie7 years ago
You can buy one of these Jiggler Pumps or build one your-self.
It's mostly used to start a gravity-feed but the jiggling should entertain the kids.
These are available at most hardware stores and boat part shops. I'm talking about Cape Town (my home) not Riyadh, I don't know about Riyadh.
Sandisk1duo7 years ago
get a plunger, and valves
saw off the handle of the plunger, install valves
when you press down, one valve will open, when you let go, the first one will close and the second one will open
rinse and repeat
