How do you concentrate citric acid?
For the meantime I'll boil it to check if it works. If results come back positive, I'll delete this question. If results come back negative, I'll let this question float around instructables for a while.
(Please do help me in putting this in the right category)
13
answers
Answer it!
As for the actual question, you don't want to boil it; that will do things to the chemical composition that you may not want. Rather, you want to make a reduction. Put the juice into a wide, shallow pot or pan, and simmer it gently (no bubbles, just steam rising up). As you leave it on, the water content will evaporate off, and you should get more and more concentrated acid.
I'm not sure whether that will increase the output or not. The acid is just an electrolyte. The current flow should be determined by the relative electronegativity of the two metals you use as electrodes.
That's not the scientific method.
It is a good idea though; I already have an idea of how to do it.
