How do you cut t-nuts/slotted nuts with a router table?
Y want to use finger joints with T slotted captive nuts like this https://www.instructables.com/id/How-to-Build-your-Everything-Really-Really-Fast/step4/The-T-nut-Crossed-T-nut-Jesus-Nut-Slotted-Insert-N/
I only have hand tools and a mini router table.
¿Is it possible? ¿Is there any other convenient joint I can use in Acrylic with just this tools? (with screws, I don't want to use glue)
Thanks
Burf4 years ago
I would would use a blind rivet nut, the only tools you need are a drill and a screwdriver.
This is in order of strength.
In Acrylic or plastic you should be able to do the T-Nuts with the mini router.
You can also use self taping screws, not wood or sheet metal screws.
Another thing you can do is pinning, drill a hole slightly smaller than wood or metal pins and press the wood or metal pins into the plastic. It pressure fits and holds the two parts together.
Joe
