loading
How do you make an ominous fog?
Ok, I need to make a fog. Problem is I don't have a smoke machine, and I don't want to get one. I am trying to figure out a way to make the fog with a chemical reaction. I can only buy so much, and don't have very useful shops near me. So all I am asking, I want to know if there's a way to make a fog, easily.
Also, if the fog is ominous, it makes it all the better.
Also, ominous fogs hug the ground and billow out.
ANY help is appreciated.
caarntedd7 years ago
What about getting a bottle of the stuff that you pour into a smoke machine and trying to burn it a different way? I don't know if the stuff is cheap or how to use it, any big brains out there that think this is an option?
XOIIO7 years ago
Dry ice and water baby, dry ice and water.
kelseymh XOIIO7 years ago
What do you use the baby for?  To produce the, er, "water"?  Won't that give you a yellow fog?
XOIIO kelseymh7 years ago
Use tap water and dry ice. It makes a  a low, ominous white fog.
+1
Aclassic, an still the best low-lying fog to be found.
"aclassic"? This is why I shouldn't multi-task.
lemonie7 years ago
Mixed beans, garlic, onions, chilli-sauce, 12 hours digestion.
L
(Dry ice is what you really need for ground-hugging)
orksecurity7 years ago
As others have said, you want a cold fog. One way to get that is dry ice in water. Another, if you need to be able to turn it on and off at need (for stage purposes, for example), is to use a standard warm-fog machine but run its output through a styrofoam cooler in which you've placed some dry ice, to cool it off. For an example of what that looks like when properly lit, see http://web.mit.edu/gsp/OldFiles/www/Archive/2000fall_sorcerer/photos/incantation.jpg
Re-design7 years ago
I don't know, the only fog I was ever able to make was promising so that wouldn't work for you use.
Awww, you beat me to that joke.  Just hanging there, like fruit from a low branch...
<snorts soda out of his nose>
You'd better get you nose looked at.  You do that an awful lot.
The really funny thing is, I was drinking coffee at the time.
Koosie7 years ago
Well, depending on how much you want, you can always use a smoke flare (like the one's on boats).  Of course, these are usually coloured and make a huge amounts of smoke.
IMO, this looks like the easiest/safest way:
https://www.instructables.com/id/the_ultimate_fog_machine/
There's a good reason why there are such things as smoke machines - lots of research has proved that their output is reasonably benign. I can't think of any benign chemisry that will give you what you want.
MAKING a smoke machine is not out of the question, and a chiller to make the smoke drop is detailed in some of the "related" links on the right here.
Steve
