How do you make jellied alcohol?
You know sterno?Its jellied alcohol.How do you turn regular alcohol into jellied alcohol?
Stew28 years ago
Kk, I kinda cheated and checked the internet... A cool recipe using egg shells, vinegar and alcohol! I hope I didn't infringe on any copyrights, but cutting and pasting was much easier than typing it all out. Make Your Own Gelled Alcohol Fuel - Canned Heat Extreme do it yourselfers can make their own gelled fuel at home with by mixing alcohol and calcium acetate (C4H6CaO4). The following instructions and measurements are from the Montville High School Science Departmental. 1. Add 25g of crushed chalk or egg shells (calcium carbonate-CaCO3) to 100ml of vinegar (water and acetic acid - CH3CO2H) and stir for about 5 minutes. This should produce carbon dioxide (CO2), calcium acetate (C4H6CaO4) and water (H2O) plus leave you with some left over chalk (CaCO3). If you are guessing on how much chalk to add, just make sure that there is a little extra after 5 minutes of stirring. 2. Remove the excess chalk by filtering your mix through some filter paper (coffee filter or napkin can be used). Set a funnel in a jar, place your filter in it and pour your suspension through it. 3. Mark the level of your solution in its container and allow your solution to evaporate off about half that volume to remove the excess water. Place your solution in an oven set on low heat or place it out in the sun to dry. If you went to far - just add the missing water. Note - if you like, you can dry out your solution completely and store the remaining dried calcium acetate for future use. 4. If your solution isn't already in the container you want your gel in, then pour it in there now. 5. Add 30ml of alcohol (ethanol, methanol, or isopropanol) to your solution and watch the gel form. Do not stir. 6. Once the reaction in complete, pour off any extra fuel.
Just use ordinary Jello. Jello shots are ethyl alcohol (whiskey) with jello.
bylerfamily (author)  ShutterBugger8 years ago
Thanks.I will try it soon.
