3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How does a BEC work?
I was wondering how a BEC (Battery Eliminator Circuit) for RC cars works.   I know it has 2 wires for the motor, a connector for the receiver, and wires for the battery.  But, I don't know how to connect it.  If someone could explain it, I would appreciate it very much.  Thanks in advance.
Jun 14, 2010. 2:54 AMrickharris says:
The receiver outputs have 3 pins on them - zero volts, power and the control signal. The BEC connector connects to the zero and power lines to provide power for the Rx. The BEc also has a voltage regulator in it to make sure the Rx isn't over powered.
Jun 19, 2010. 1:33 PMrickharris says:
You can't change the output of the BEC - but it will regulate the input voltage (within reason) to the 5 volts the receiver needs
Jun 13, 2010. 4:09 PMRe-design says:
I'm not sure what you're not getting.
The BEC just provides a way to eliminate the battery for the receiver.
The two motor wires go to the motor.
The two battery wires go to the battery.
And the receiver plug from the BEC goes into the receiver battery socket.
Now, can you be a little more specific about what you don't get?
Jun 14, 2010. 4:34 AMRe-design says:
The channel outputs provide a direct connection to the battery.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
