loading
How does a carborator work?
in a motor
yo man7 years ago
it makes your moter go
cheezies (author)  yo man7 years ago
ur so funny its not even cool.
lemonie7 years ago
one example
They use the Venturi effect to introduce fuel into the engine. These days fuel-injection is more common. One of the principles of operation is to control airflow, in cars it's usually a butterfly valve attached to the throttle cable, in small 2-strokes a bit different.
L
cheezies (author)  lemonie7 years ago
wow....that went right over my head.
If you just wanted to clean it, should have asked. The easiest way is to blast it with carb'-cleaner 3M carb'-cleaner
Otherwise UK bike Forum on carb-cleaning
L
yeah...i didn't realize that until i read the thing...im kind of mechanically challenged that way.
vince 097 years ago
well you have your accelerator pump for one, and it dose what you think it dose. when you push down on the gas peddle it pumps gas into your primaries. than your main jets work off of a vacuum, as air rushes past the jet it pulls gas out of the jets and into the intake. at an idle you have your curd idle and it works the same way as your jets but the holes are smaller and it doesn’t put as much gas into the intake. dose that answer your question?
cheezies (author)  vince 097 years ago
yes it does....now i can fix my car and i owe it all 2 u. :) -i just needed 2 clean it.
thats good. i am glad i could help.
Phil B7 years ago
Carburetor is the correct spelling. It is frequently incorrectly spelled.
cheezies (author)  Phil B7 years ago
thanks 4 that...
CameronSS7 years ago
Appropriately enough, HowStuffWorks has a writeup.
