How does rolling the head of a Stick (Ex. Arrow head/Spear) make it Harder?
I have seen videos on Youtube & Instructables about make a Spear/Arrow head stronger, i was wodering if this is due to tempering (Ex. Steel Heating, cooling rapidly for stronger atomic bond) or due to some other method of strengthing I do not know about ( I only know the Steel method due to mass History/Science channel fanatical-ness)
Plase help me uderstand this.
Along with tempering, rolling can "work-harden" the steel - the stress of having been slightly deformed in the rolling process strengthens the steel against further deformation.
If the rolling is done in or against a carbon-rich material (charcoal, coke, etc.), there will also be what's called "case-hardening." Steel generally gets harder as more carbon is alloyed with the iron that it's made of, but it also gets more brittle. With case-hardening, you can make a shaft (or tang, or whatever) of lower-carbon steel that is tough enough to withstand blows and impact with shattering; and then heat-treat just the surface of the blade to absorb extra carbon, forming a "case" that is "hard" enough to form and hold a good sharp edge.
(For the difference between "hardness" and "toughness" - a china plate is hard but brittle, a rubber dog-toy is soft but tough.)
If you're talking about rolling a wooden stick, it would probably be a simple case of compression...that is, by rolling the end of the stick you are compressing the wood fibers, making a denser area where it is rolled. As long as you don't roll it so hard that the fibers essentially delaminate, ie, become separated, a denser area of wood is automatically harder. If metal, well i think Gorfram already covered the subject pretty thoroughly.
Bio:I love War Games,Books,and assorted oddities.I came here to learn to make stuff in my spare time.I'll be thankfull if you can please PM me some ideas that go along with my Interests.Thank you!
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
