How exactly did this happen in this c++ output window?
Well this is a pretty easy program i made while practicing, by mistake i entered "a", as the first element of my matrix and the whole program displayed results(i wasn't able to add other elements it directly displayed the results")
The code which i used:
#include<iostream.h>
#include<conio.h>
#include<iomanip.h>
void read(int a[][10],int r,int c)
     for(int i=0;i<r; i++)
             for(int j=0;j<c;j++)
                     cin>>a[i][j];
void display(int a[][10], int x, int y)
           cout<<endl;
           for(int i=0; i<x; i++)
                        for(int j=0; j<y; j++)
                                cout<<setw(5)<<a[i][j]<<" ";
                        cout<<endl;
void displayt(int a[][10],int r,int c)
     for(int i=0;i<c; i++)
                      for(int j=0;j<r;j++)
                              cout<<setw(5)<<a[j][i]<<" ";
                      cout<<endl;
int main()
    int m,n;
    int a[10][10],b[10][10];
    cout<<"Enter the dimensions\n";
    cin>>m>>n;
    cout<<"Enter the first matrix\n";
    read(a,m,n);
    cout<<"entered matrix:\n";
    display(a,m,n);
    cout<<"Transpose:\n";
    displayt(a,m,n);
    getch();
    return 0;
Picture of How exactly did this happen in this c++ output window?
frollard6 years ago
because a was already defined, when you fed it 'a' it might have referenced the values of the existing a to put into a, since it was a valid data type...not sure but what happens if you enter z or x or h?
ankur2893 (author)  frollard6 years ago
no no man. a being a variable and a being given as a character type input are two different things, it has no reation what so ever. as far as entering z x or h is concerned, it gives the 4, 0 and 127 as constant input in their respective places rest of the values change!
just thought it might be some goofy byref problem, I know I've had programs accidentally grab the wrong chunk of memory before. perhaps a variable overflow?
the 'wrong chunks' are called garbage values, they are random values initially stored in a variable when it is declared. thus u need to initialize the variable. that i understood. what i didnt understand is why that 4, 0, 127 remain constant and why does the compiler prints the results even if the datatype i've entered is incorrect?
