How many LEDs can a 9 volt battery power in parallel?
Basically what the title says
PratyushJ9 months ago
One 9V battery will give you somewhere between 120 and 200 hours of illumination with the simplest circuit, a series resistor. With a good switching voltage converter circuit you should be able to get more than 600 hours.
lemonie8 years ago
What sort of LED, which 9V battery?
You could run quite a lot at low current with a good battery.
L
If only for a short time a 9-volt can put out full amps at completely short circuit.
Agreed - quite a few.
As for how many - it would make a lot of sense to run series strings of 2-4 leds to better utilize the whole 9 volts and put THOSE in parallel with each other.
Zem (author)  frollard8 years ago
I've heard of that before, but I don't exactely understand how to do that?
frollard Zem8 years ago
Use http://led.linear1.org/led.wiz  this calculator
Each led has a forward voltage.  2 leds in series uses 2 times this voltage...etc.
each led has a CURRENT.  2 leds in PARALLEL use 2 times this current. et al.
9 volts is way more than 1 led needs, and you'd need a resistor to burn off the excess.  If oyu have 3 volt leds, you could put 3 in series and use a VERY small resistor to prevent overcurrenting the leds.
The link you gave me doesn't work =/ got any others?Okay! Thanks!!
always works!
tell it 9 volts source
3 volt leds
20 miliamps each
and total # of leds you wish.
Awesome! Thanks!
remove the &nsbp from the end.
Okay! Thanks!!
Zem (author)  Zem8 years ago
exactly*
Zem (author)  lemonie8 years ago
Blue or red LEDs, and a Panasonic 9v.
red leds are 2-3 volts, blue are 3.5.
Check the exact specifications on the packaging or model number.
Best answers can't be awarded on replies, but you've got it in theory...
L
Zem (author) 8 years ago
Awesome.
Thanks everyone!
