3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How may I make a widemouth carpet-bag style bag?
I'm not really sure of what they are called, but I would make to make a bag much like this one here. Just basically the opening clasp style. Any ideas?
Dec 7, 2011. 3:48 AMcanucksgirl says:
To construct a bag like this, you'll need to focus on structure since its designed "to stay open on its own". This can be accomplished with some boning. A rigid wire would work quite well (like coat hanger wire). You would want to pre-bend it to the finished shape and then cover it with a sturdy material like leather (so the wire couldn't poke through) and then sew it into the fold where the zipper is attached so that its hidden.
Along both ends there are corded seams (running vertically that look like tubes of material). Instead of the traditional cording you'll again, want to use wire. The purpose of this is to give the sides enough support to stay upright when the bag is opened. The vertical seams are also what support the opening and prevent the bag from falling flat when opened.
To make the cording, measure the height of the bag and cut 4 lengths of wire. (There are corded seams at each corner of the bag.) Wrap the wire with some sturdy material and then cover with a strip of the material you plan to finish the bag in. Then sew a seam into each strip to keep everything together. Essentially you'll have a fold with the covered wire sewn inside. Then when you match one of the bags' sides with an end, you'll place the corded strip in between and then sew it together.
The base of this bag shouldn't need any support structure, but you could certainly add it if you felt the need to.
I hope this helps. If you in fact get this bag constructed, I would love to see a picture and/or hear how it went. - Feel free to PM me with the results.
- canucksgirl
Dec 8, 2011. 1:01 PMcanucksgirl says:
Walrosity - I spent my lunch hour constructing a visual aid for you. It doesn't cover every step (but I did as much as I had time for). Save the image for your reference.
Based on the fact that you're new to sewing, I would recommend that you make a practice bag with less expensive materials. It will help you to learn as you go along.
You can get cheap canvas from a hardware store (drop cloth) and use that for your practice.
- canucksgirl
Dec 8, 2011. 11:41 PMcanucksgirl says:
Not a problem. Glad to help :)
btw, if you want more help from other members, then leave the question unanswered. If you don't want more replies mark the comment with 'best answer' and then you're done.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
