How powerful is this amplifier?
Specs:
music power output: 7W / 4ohm
RMS output: 3.5W / 4ohm or 2W / 8ohm
total harmonic distortion: 0.05% (1W / 1kHz)
frequency response: 20Hz to 20kHz (-3dB)
signal/noise ratio: 86dB (A weighted)
input sensitivity: 40mV / 150Kohm
overload and short-circuit protected
supply voltage: 15V DC (8 to 18V DC possible) / 0.5A
dimensions: 2.2 x 1.4"
I'm assuming that this would be good enough for use as a headphone amp? Would I be able to run this off a 9V battery?
5
answers
Answer it!
Any ideas on what nifty project I could use this amp for? Doesn't seem like it'd be ideal to have it run off of batteries.
Good enough for headphones - depends on the quality you are after.
Able to run from 9V battery? Assuming, you mean a PP3 battery, a fresh one can drive it but it will stop working, once the battery voltage drops below 8V (if the data given is correct) And if the device really needs 0.5A of current, the battery voltage will drop fast.
Steve
