3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How practical is using bismuth for stovetop heat transfer?
A stove that heats pots by induction is a nice idea, but it is still not common and will not work with all pots.
Suppose, instead, the pot and resistive heating element were placed in a well that was filled with bismuth or another metal that has a low melting point. How would the efficiency of this compare to a pan sitting on an induction cooker, gas stove, or ordinary resistive heating element? What would be some important practical considerations, if this were implemented?
Mar 21, 2009. 11:05 PMCameronSS says:
I don't know for sure about efficiency, but I would guess that the conductive efficiency would be relatively high.
Practical consideration: even bismuth, with a "low" melting point, would have to be above 520°F to remain liquid. This means that you would have a well filled with very hot metal, which would very easily burn a hand accidentally placed in/on it. In addition, it would remain hot for a long time after turning off the heat source, due to the high thermal mass of any metal, particularly bismuth. Finally, if you wanted the metal to be molten, you could not have a "low heat" below the melting point of that metal.
I'm not trying to discourage you, it's an interesting concept. However, it seems to me to be inherently dangerous, and would require extensive safety precautions.
Mar 22, 2009. 1:29 AMNachoMahma says:
. It doesn't seem to me that it would be that much more efficient at heat transfer than just sticking the pot over a "regular" heating element and insulating the pot. At least not enough to compensate for the difficulties and dangers involved with using molten metal, especially in an open vat. . You will lose a lot of energy melting the metal each time and then lose more when you have to remove the pot before the metal freezes. . What to do with the bismuth that sticks to the pot?
Jul 20, 2009. 8:25 PMkillerjackalope says:
Eh pools of molten metal? Practical, always... Actually one day while incredibly bored I considered attempting to coat my kitchen floor in bismuth, to see if I could, however I do know it can be very unsticky and it's not toxic to the best of my knowledge, could you fry food in metal?
Mar 22, 2009. 2:05 AMfrollard says:
Heat transfer would be grossly more efficient, but as mentioned, heat storage and practicality are out the window. Surface area of a liquid touching v. surface area of a conductive element is a pretty big difference. Inductive cooktops are HUGELY more efficient, but as mentioned dont work with all pot types.
Mar 22, 2009. 12:57 AMlemonie says:
Some low-melting toxic heavy metal alloys for information.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
