How should I modify these code to send sensor reading to another Arduino?
Idea is to make a weather station using two Arduinos. They would communicate using RF transmitter and receiver. I tried to use VirtualWire library and its examples (named transmitter and receiver). I can send and print characters but I can't do the same with number(positive and negative). It's going to send temperature (both positive and negative) and barometer readings.
In my opinion I should send them in an array (int).
How can make this work? Is there a better option for wireless communication?
Thanks
steveastrouk2 months ago
Likewise decimal number 35 = 3 x10 + 5x1
Lets delimit the numbers with a space character " "
At the transmitting end
Transmit a " ", start new number
Transmit character "3',
transmit character "5"
At the receiving end:
If char=" " answer =0
While char <> " " DO
answer=(answer*10)+char
+1
CR LF
I often use the LF as the start of a reception packet, and the CR as the end. It makes processing messages a snip, and the output is human readable !
Makes easy decoding..
iceng2 months ago
A value number binary 0101 = decimal 5 = ASCII character 0011 0101 = Hex 35...
Convert numbers into characters !
+1
