How should I recharge a 7.4V battery?
I have a 7.4V rechargeable battery and I'm wondering what voltage I should be charging it with.
would 9V work?
Are there any general guidelines for recharging batteries?
Specs:
7.4V
1400 mAh
Lithium-ion
Was originally used in a NXT LEGO robot.
Thanks!
Ryan
May 2, 2012. 9:16 AMThe Skinnerz says:
It is generally considered a bad idea to try to charge lithium batteries without the proper charger or a voltage/current limited power supply. If you get it wrong, lithium batteries are likely to be damaged, catch fire or in some cases explode.
If the original application is still able to charge the batteries, that is the best option. Otherwise, you should build or buy a suitable charger. While you are trying to charge them you should monitor the temperature to try to avoid any serious issues.
May 3, 2012. 8:04 AMThe Skinnerz says:
Make sure you find instructions for a Li-Po battery charger at the correct voltage, as attempting to use a charger designed for other battery types can be dangerous.
May 4, 2012. 9:33 PMastroboy907 says:
No! Make sure the battery charger you are using is rated for Lithium ion (or li-ion). Just a plain old charger, while might work, could blow up your battery. I think you can buy chargers on ebay rated for a 7.4v for pretty cheap if you have $10 or so
May 7, 2012. 5:20 AMastroboy907 says:
Just emphasizing ;)
May 3, 2012. 8:09 AMpfred2 says:
Whatever happens post an article here and share your adventures with us! It looks to me like you already have one image.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
