loading
How to Blinking LED at 230V using one risistor ?
what is that risistor value and watt???
iceng3 years ago
Well, you can easily buy an LED that blinks.
Calculate the current from 9V example 9V-3V = 6V ||| I = V/R = 6/82 =.07317A = 73ma
Next calculate for 230 VAC x 1.414 = 325 VDC peak less the 3V LED is 322 VDC assuming a 5cent 1N4006 diode prevents LED destruction when the power line AC reverses R = V/I = 322 / .07317 = 4,400 ohms.
Power = V*I = V*V/R = I*I*R = (73ma)^2 x 4.4K = 23 watts which falls to 15 Watts because of the 1N4006 diode preventing inverse current half the time.
A
iceng iceng3 years ago
Here is the minimal circuit you want and one I would build myself.
This killer circuit is extremely dangerous to a beginner YOU
BUT I have an engineer's understanding and will work with one hand in my pocket to
Avoid a 300 volt Shock pushing a Lethal current across my chest !!!
rickharris3 years ago
Use a cheap wall power supply - even a phone charger should do it.
Need more details about the LED you intend to use Crystal ball broken.
