3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to I display voltage on a 7 segment display?
Okay, I've never actually come across this before or needed to do this but now i come to it, i realise I am really lost to it. What i need to do is display a 3 digit (hundreds eg. 342) number on three 7 segment displays. So pretty much I just need a 3 digit voltage read-out to be incorporated into a portable design. I've been looking around and have come across the Analog to Digital converters, and understand how they work, but I'm not sure how to incorporate them or to put it to any use. So if anyone knows or has a schematic or any information I could work off, please help. :)
Thanks
Pyroten
Aug 3, 2009. 1:15 PMDustinEE says:
You can try a TC7107. It's a 40 pin IC chip that will split up the voltage between 4 7segment LEDs into 1's 10's and 100's and only displays a 1 on the thousands 7segment LED allowing you to have 1999 be displayed.
Jun 2, 2009. 8:34 AMkelseymh says:
Is this a homework problem in a double-E class? If not (or even if it is :-), you should look up "digital voltmeter schematic" in Google. If you didn't realize that "voltmeter" is what you're trying to build, that might explain why you didn't find anything when you searched Google before posting this question.
Jun 2, 2009. 10:37 PMkelseymh says:
:-) Good luck! The thing is, you need a voltage divider (with high-precision resistors) to get the 0-9 volts, 10-90 volts, and 100-900 volts separated, voltage-based ADCs (or high-precision resistors with current-based ADCs), then seven-segment drivers to convert the ADC's digital output to lines output for the digits. The schematics on Google detail all of this.
Jun 29, 2009. 6:20 AMPKM says:
you need a voltage divider to get the 0-9 volts, 10-90 volts, and 100-900 volts separated
I'm not sure I understand this part- given a voltage between 0-1000V how can you separate out the digits? I would have thought this problem just needs a 10-bit or greater ADC, and then I'm not sure how I'd turn that into three decimal digits in a simple manner (unless there are multi-digit seven-segment drivers that take that many bits of input). Could always display it in octal :)
Jun 2, 2009. 7:28 AMevildoctorbluetooth says:
Buddy im confused, what is it that you are trying to measure? i know this isnt an answer, its more of a comment. sorry
Jun 3, 2009. 8:09 AMevildoctorbluetooth says:
So you specificly want to build one, as opposed to buying one? Digital voltmeters are quite complicated, and it would need calibrating. hope that hasnt put you off. ak
Jun 2, 2009. 8:32 AMkelseymh says:
He wants to design a digital voltmeter for himself, from scratch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
