How to Make a RGB LED Mood without Microcontrollers (with 3 led, 3 potentiometers ) I would like a schematic circuit?
12
answers
Answer it!
Use 250R (or 500R) pots and connect the centre pin to one of the end pins. Now wire the relevant LED and resistor to this so you've got the pot, the resistor and the LED in series. Do this for the other 2 LEDs and then wire each of these circuits across the supply.
You can now adjust each LED over the full range of brightness without fear of damaging it.
I was saving him finding the usual arrangement which wires a 10k pot or similar to the led so you get nothing, nothing, nothing, sizzle!
Yes, and 3 resistors to protect the LEDs from burning out.
(Although it's more variable current than variable voltage.)
All the information you need is in my answer :-
Look at the specification of the LEDs you're using. The red one will be something like Vf = 1.8V, If = 20mA. Put these numbers into the calculator I've linked along with your supply voltage and it will come up with the value for the resistor (for example 180R if you're using a 5V supply).
The circuit for each LED will be exactly the same as the calculator shows you, except you'll also put in a potentiometer in the circuit as well, like THIS.
What voltage are you going to be running it from?
