How to add a memory function when I push a button
I have a proyect with a MLX90614 (an ir infrared thermometer with I2c), and the output temperature is displayed in a oled 128x64 I2c, I am using an arduino pro mini, the code works well, but i want to add a function:
I want to press a button that saves the temperature shown, in the right down corner of the screen, and if I press it again to save again the temperature.
It is like a memory function, I searched on the internet and I discovered that there is a memory in the arduino called eeprom but i have problems combining that function with the code.
Any help appreciated. Thanks.
Code:
#include "U8glib.h"            // U8glib library for the OLED
#include <Wire.h>              // Wire library for I2C communication
#include <Adafruit_MLX90614.h> // MLX90614 library from Adafruit
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE); // I2C
void draw(void)
  u8g.setFont(u8g_font_profont15r);        // select font
  u8g.drawStr(1, 12, "Object Temperature");//
  u8g.setFont(u8g_font_profont29r);        // select font for temperature readings
  u8g.println("°C");                        // prints C for Celsius
  u8g.setPrintPos(35, 55);                 // set position
  u8g.println(mlx.readObjectTempC(), 0);   // display temperature from MLX90614
Serial.println(mlx.readObjectTempC(), 0);
// u8g.drawRFrame(15, 20, 100, 30, 10);     // draws frame with rounded edges
void setup(void)
  Serial.begin(9600);
    mlx.begin();  //Receive data from the sensor
void loop(void)
  u8g.firstPage();
  do
     draw();
  while( u8g.nextPage() );
  delay(1000);  // Delay of 1sec
Downunder35m5 months ago
No need for Eeprom storage, all you need is assing the current temp to a variable (if not already done in the sketch) and add that value to the display output in the way you like.
The button would only need to update the display info, or change the value of the variable if yu use a second one for the stored temp.
+1
He speaks the truth.
EEprom memory is for recall, of a temperature numeric, after a uP power interrupt..
