How to apply wet-slide decals?
i have been experimenting with wet-slide decals, to do complex graphics, but can't figure out how to make them work. They are essentially a piece of thin plastic on paper backing. You print on them, using a printer, then immerse them in water to get the paper backing to come off. Then, you slide the decals onto whatever surface you have. finally, you use a softening agent, to get them to meld onto the surface without edges. i have spent 10+ hours, trying to make a 3"x2" decal. No dice. And none of the guides online have worked for me.
I have a couple of problems:
1. can't get decal to not lose its proportions—i.e., stretches when i seat it
2. can't get print not to bleed (ink-jet version) or flake (laser version)—even when i use a fixative
Also, if i try to cut decal to just dimensions of surface i am applying to, the edges tend to curl up and refuse to flatten out—without further causing 1 and 2 above.
20
answers
Answer it!
~draconis out~
If you want use them upon your car or moto (my case) you need to prepare them before with some plusses.
With common paper glue stick (where I live a famous brand is pritt) place a layer (don't put too much glue it must be a flat layer) of glue on it and let it dry.
Clean the target surface, then use fine polish and clean again, then dry the surface and if possible maintain it warm (a phon might help)
Place your decal as usual and when dry spray it with a transparent paint, it might be enough.
My decals was placed in this way (but I put them mirrored) then I've paint the entire piece with transparent paint, it still endure.
These will soften and protect the decals while allowing them to slide and remain wet and viable. The finishing solution protects your work.
Good luck!
Perhaps searching some model making sites (particularly military types if my memory serves) could help your cause.
They work MUCH better on flat surfaces.
Soak them only enough to get them to release.
Try to find a water proof ink for your ink jet.
In the end, I just paid a service to print my decals for me. I was building a Scale R/C plane and the decals were the detail I needed.
