loading
How to build circuit for (2) small laser pointers switched from one transistor used as a switch.?
I am building a device with two 5mW lasers 3.5 volt switched by a sensor and transistor switch. When both are in the circuit only one is on. what is the proper way to switch two lasers from one sensor/transistor?
iceng5 years ago
That is because the lower forward voltage Laser LED predominates and
does no let the other get the voltage level to turn on.
Try putting a resistor ( 1 or 2 ohm ) in series with each Laser diode.
A
+1
Either that, or just put them in series on a 7V supply.
Even better !
lemonie5 years ago
Could you expand upon "When both are in the circuit only one is on"?
You want to switch between one and the other, using a "sensor" - what type of sensor?
L
