loading
How to change 5v into 3v using only resistors?
I need to change 5 volts into 3v, using only resistors, to power a LED, I can't use a voltage regulator, because the LED is to see if the current voltage regulator is working, I am happy to reply to questions that would help you answer it.
Thanks
AndyGadget6 years ago
Unless you're doing something strange, there's no need to convert to 3V for the LED - Just do the limiting resistor calculation for 5V.
Can you give more details of the actual circuit you're building.
alexw2150 (author)  AndyGadget6 years ago
I'm doing this (http://windisch.co.uk/robots/howto/voltage_regulator.htm) for a battlebot. The battery I'm going to use is a 7.4v lipo I've used a L7805 to get it to 5v but I just want to add a LED so that I can quickly check to see that I has power.
Ah, I see - You've fallen into the old trap.  You have a led which says something like Vf = 3V.
What it actually means is that you are going to lose 3V across the LED.  Vf is the forward voltage drop.  The correct way to do this is to drive the LED with a higher voltage than that and use a series resistor to set the current to a sensible value. Go to the site I've linked and use the first scenario.  (I would actually set the current to 15mA which will be very nearly as bright as the 20mA LEDs are usually rated for but will save you 5mA, so slightly longer battery life.)  For this you'd use a 150R resistor.
Okay, thanks i ended up with a 150ohm resistor.
That's the one.
The actual calculation is the supply voltage minus the LED Vf divided by the desired LED current, which is (5 - 3)/0.018 = 111.111 ohms.
Round this up to the next preferred resistor value and you have 150R (although 110R would do fine).
lemonie6 years ago
Think about the current you want not the voltage.
Plug your numbers in here:
http://led.linear1.org/1led.wiz
L
alexw2150 (author)  lemonie6 years ago
Thanks, it works.
dudenr336 years ago
But you should note that the LED needs a limiting resistor for the current which causes another voltage drop!
alexw2150 (author)  dudenr336 years ago
I know but there are less areas for error on a resistor.
dudenr336 years ago
You can build a voltage divider:
http://en.wikipedia.org/wiki/Voltage_divider
