How to connect 16.4 Ft RGB Color Changing Kit with LED Flexible to a Battery and waterproof?
I have a project in which I want to connect at least 10 ft of RGB LED waterproof lights to be use in the water.  I bought 16.4 Ft RGB Color Changing Kit with LED Flexible Strip, Controller + Remote and Power Supply, 5050rgb Kit. I  want to be able to connect it to a battery  and use it on my water board wirelessly with a remote control to activate the lights. The kit came with a remote control, but  not sure which battery would be a good choice or where to buy it.  Here is an Idea of what I am looking for http://www.youtube.com/watch?v=_XlioqLlF_g  .I want to make it and I hope you guys can help. Thanks :)
Jan 4, 2012. 8:31 AMsteveastrouk says:
Got a link for the actual thing you have ? What voltage do you need ?
Steve
Jan 13, 2012. 1:18 PMsteveastrouk says:
7A is quite a lot - that's 84Watts of lighting. What battery exactly do you have in mind ?
How long do you want it to be lit for ?
Like I said, have you got a link to where and what you bought ?
Steve
Jan 14, 2012. 10:24 PMsteveastrouk says:
How long do you want it to be lit for ? I suggest you use a sealed lead acid battery, in a waterproof case. A 3Ah battery will last one hour, if you have everything on full
Jan 15, 2012. 4:48 AMsteveastrouk says:
You'll need a 4x 3 = 12 Ah battery.
Like this:
http://www.batterymasters.co.uk/Product-Ultramax-NP14-12,-12V-14Ah-Sealed-Lead-Acid-Rechargeable-Battery_2243.aspx
...that is at full brightness, and the whole strip, for more than 3 hours.
Jan 6, 2012. 11:28 PMiknowvations says:
Did you get any user manual with it ? As it will help you to get all technical answers .
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
