3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to connect 2 motors in series so both work?
I've connected two motors in series and only one will work at once. Both motors seem to be fully functional. Do I need to add more power? Both normally take 3 double As and I currently have it connected to only 4.
Please be gentle, high school physics class seems like a million years ago.
Oct 18, 2010. 7:39 PMcaarntedd says:
Try connecting them in parallel.
Oct 18, 2010. 8:11 PMNachoMahma says:
. +1. It may help to put a switch in series with one of the motors so that you don't start both motors at the same time.
Oct 18, 2010. 8:23 PMorksecurity says:
+1.
Remember, a DC motor is continually making and breaking connections in order to transfer the magnetic interaction from coil to coil. That means that if they're in series, each motor is continuously getting its power interrupted. Not a good situation. Even without that, if the voltage drop across each motor was supposed to be 4.5 V, you would need 9V across the pair.
Put them in parallel. It really will work better.
Oct 19, 2010. 1:25 PMlemonie says:
Are they identical? They sound not.
L
Oct 18, 2010. 11:44 PMsteveastrouk says:
You'll need six cells to get them to go anyway.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
