How to control DIY linear actuator with end switches and sensor input?
I want to build a DIY 12v DC linear actuator, using Arduino uno. The actuator is DIY so it does not have any position tracking.
I want to use 2 relays to control the direction of the actuator, two end switches, and one sensor input (preferably a photo resistor)
The sensor, and end switches are connected to Arduino UNO R3 as inputs and relays as outputs.
When the sensor is energized motor moves forward until it hits End Switch No 1 and stops;
When the sensor its not energized motor moves backwards until it hits End Switch No 2 and stops:
And be able to repeat this program whenever  the sensor is energized.
I would be greatly appreciate if someone can help me with this sketch, because i don't have any experience with Arduino code.
Thank you and have a grat day.
KISELIN25 days ago
I have a "ible" that maybe helps you
https://www.instructables.com/id/A-Simple-Control-...
It can be very dangerous to use a microprocessor to control an actuator in the way you describe. It is ALWAYS better to make the relays cut the power when the actuator hits the limit stops IN HARDWARE.
+1
catalin1704 (author)  iceng1 month ago
I intend to use a fuse, or a resetable fuse (i have one on the drill, wich is the source of the motor) to protect the motor burning up in case of malfuntion, and i don't know how to make the exact thing without using a microprocessor
Its very easy, see my diagram
catalin1704 (author)  steveastrouk1 month ago
Thank You.
I will try this schematic
With this circuit, you only need a photosensor circuit, no need for a microprocessor
The circuit I've posted is ideal for a chicken coop.
+1 Steve
I was opening my schema program when my iPhone signaled a comment and behold you saved me the effort !
Now, I don't need to produce.. My sky is depressing, cold, cloudy and dark.
Hope you have a nice weekend.
BTW catalin only needs a pair of 47K resistors and the normally open contacts of those limit switches to let his Arduino know when a limit is reached ;-)
Ooh. Your little wrinkle at the end there should go in the diagram. I like that !
Also, I suppose at a pinch, you could use two relays. Relying on the XOR of the control signals would still be safe ?
In the 'teens (deg F) in State College today.
Safe for a chicken maybe ;-)
Our mountain town changes 60 deg F twice a day..
I rewrote a program based on a chicken coop door found on YouTube,
and looks promising:
int Sensor = 6; // LDR Sensor Pin
int ReedPin1 = 2; // Reed Switch 1
int ReedPin2 = 4; // Reed Switch 2
int MotorFW = 8; // Motor Forward
int MotorRW = 10; // Motor Backward
int Reed1 = 0;
int Reed2 = 0;
int Light = 0;
void setup()
pinMode (MotorFW, OUTPUT); // MOTOR PINS SET AS OUTPUT
pinMode (MotorRW, OUTPUT);
Reed1 = digitalRead(ReedPin1); // SET ALL SENSORS AS DIGITAL
Reed2 = digitalRead(ReedPin2);
Light = digitalRead(Sensor);
if (Reed1 != HIGH) // IF REED(1)IS NOT ACTIVATED
while (Reed2 != HIGH) // WHILE REED(2) IS NOT ACTIVATED
digitalWrite(MotorFW, HIGH); // MOTOR RUNS FORWARD
digitalWrite(MotorRW, LOW);
Reed1 = digitalRead(ReedPin1); // CHECK REED SENSORS POSITION
digitalWrite(MotorFW, LOW); // STOP MOTOR
void loop()
Light = digitalRead(Sensor); // SET LDR SENSOR AS DIGITAL
Reed1 = digitalRead(ReedPin1); // SET REED SENSORS AS DIGITAL
if (Reed1 = HIGH && Light == LOW) // IF SENSOR REED (1) IS ACTIVATED AND LDR IS OFF
delay(1000);
motordown(); // MOTOR RUNS BACKWARDS
else if (Reed2 = HIGH && Light == HIGH) // IF SENSOR REED (2) IS ACTIVATED AND LDR IS ON
delay(1000);
motorup(); // MOTOR RUNS FORWARD
// MOTOR FORWARD FUNTION
void motordown()
if (Reed2 = HIGH && Light == LOW)
delay(1000);
while (Reed1 != HIGH) // WHILE REED (1) IS NOT ACTIVATED
//MOTOR BACKWARDS FUNCTION
void motorup()
if (Reed1 = HIGH && Light == HIGH)
delay(1000);
while (Reed2 != HIGH) // WHILE REED (2) IS NOT ACTIVATED
digitalWrite(MotorFW, LOW); // MOTOR RUNS BACKWARDS
digitalWrite(MotorRW, HIGH);
