How to create a new folder and text file in php.?
I want to create a new folder and a text file while uploading image. I can upload picture but cannot able to create a new folder where uploaded picture directly upload to a new folder. Can anyone help me?
<?php
//define a maxim size for the uploaded images in Kb
define ("MAX_SIZE","100000");
//This function reads the extension of the file. It is used to determine if the file is an image by checking the extension.
function getExtension($str) {
$i = strrpos($str,".");
if (!$i) { return ""; }
$l = strlen($str) - $i;
$ext = substr($str,$i+1,$l);
return $ext;
//This variable is used as a flag. The value is initialized with 0 (meaning no error found)
//and it will be changed to 1 if an errro occures.
//If the error occures the file will not be uploaded.
$errors=0;
//checks if the form has been submitted
if(isset($_POST['Submit']))
//reads the name of the file the user submitted for uploading
$image=$_FILES['image']['name'];
//if it is not empty
if ($image)
//get the original name of the file from the clients machine
$filename = stripslashes($_FILES['image']['name']);
//get the extension of the file in a lower case format
$extension = getExtension($filename);
$extension = strtolower($extension);
//if it is not a known extension, we will suppose it is an error and will not upload the file,
//otherwise we will do more tests
if (($extension != "jpg") && ($extension != "jpeg") && ($extension != "png") && ($extension != "gif"))
//print error message
echo '<h1>Unknown extension!</h1>';
$errors=1;
else
//get the size of the image in bytes
//$_FILES['image']['tmp_name'] is the temporary filename of the file
//in which the uploaded file was stored on the server
$size=filesize($_FILES['image']['tmp_name']);
//compare the size with the maxim size we defined and print error if bigger
if ($size > MAX_SIZE*10024)
echo '<h1>You have exceeded the size limit!</h1>';
$errors=1;
//we will give an unique name, for example the time in unix time format
$image_name=time().'.'.$extension;
//the new name will be containing the full path where will be stored (images folder)
$newname="images/".$image_name;
//we verify if the image has been uploaded, and print error instead
$copied = copy($_FILES['image']['tmp_name'], $newname);
if (!$copied)
echo '<h1>Copy unsuccessfull!</h1>';
$errors=1;
//If no errors registred, print the success message
if(isset($_POST['Submit']) && !$errors)
echo "<h1>File Uploaded Successfully!</h1>";
echo "$image_name";
Jayefuu6 years ago
At least your code is well commented!
Where in that code do you attempt to make a new folder? I see no reference to the function mkdir....
http://php.net/manual/en/function.mkdir.php
If you've tried to use it in your script and failed, have you written a separate script with the sole purpose of creating a folder? When debugging start simple, split everything apart and find out what works and what doesn't.
nazarkhan (author)  Jayefuu6 years ago
Thanks Jayefuu for the prompt response.
In fact I am new to php. I am trying using mkdir code but it's giving me an error.
Please help me.
What's the error?
Get rid of all of the gumpf in the code above and start anew. Make a script that JUST creates a directory. That's as simple as you can make it. Does it work? If not, what is the error?
Jayefuu Jayefuu6 years ago
Oh, and since it's making folders, have you checked that it has permission to add folders?
If you're using PHP locally you shouldn't have a problem. If it's on a web server somewhere, check the permissions, I use Filezilla as my FTP client, you can browse to a folder and right click and then click "File Permissions"
I am using Cute Ftp and i have checked the permission as well.
I will tell actually what I am looking for. Please visit.
http://www.nazarkhan.com/abc
I need anyone upload picture on the server without any login and will create a folder in images folder with a picture.
Right now it saves in images folder but not creating a folder inside.
I have inserted mkdir code but its giving me an error but picture uploaded successfully
Warning: mkdir() [function.mkdir]: File exists in /nfs/c04/h04/mnt/80175/domains/nazarkhan.com/html/abc/index.php on line 154
my code is:
echo '
$errors=1;
mkdir("images", 0700);
if (!$copied)
echo '
Copy unsuccessfull!
$errors=1;
echo "
echo "$image_name";
That's not an error, it's a warning. It doesn't think it needs to do it, because the folder already exists. Do you have a directory called images? You said you were going to name it something unique...
Try these, I've never used PHP's mkdir function but this is what I'd look for:
1) Is your path correct?
2) If you're not sure your path is correct, can you use a different function to put your current path into a variable?
3) Did you try as I suggested and create a separate script that JUST creates a directory? Get that working then use what you learn in doing so to make your other script work.
4) Is your path unique?
Thanks Buddy.
Now I can able to create an folder with unique file name but picture is saving on the root. I am trying to save picture in the folder.
$dirPath = "images/$image_name";
$copied = mkdir ("images/$image_name", 777);
if ($result == 1) {
echo "images/$image_name". " has been created";
} else {
echo "images/$image_name". " has NOT been created";
$copied = copy($_FILES['image']['tmp_name'], $image_name);
if (!$copied)
echo '
Copy unsuccessfull!
$errors=1;
Shouldn't:
be:
$result = mkdir ("images/$image_name", 777);
Other than that, you've not included the code that saves the picture
Could you please help me and correct my coding
I am using this code saving picture but doesn't save in the specific folder it's save on the root folder
Please help!
You need to prepend the name of the folder to $image_name.
So:
$image_name = $image_name."/".$image_name;
This copies the image to the new folder you just made. Right?
Boss,Still I can't figure out how to save picture in the folder :(
ïmages/image_name
if ($result == 1) {
} else {
