3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to extend a power switch on a projector?
Well, I went and finally bought one of those cheap projectors off of ebay for the pourpus of replacing the lamp, I almost have it finished and at this point Im thinking about where to mount it and how to run power etc... The problem I have encountered is that it will be in a place where it will be inaccessable to me, so I was wondering  If I could extend the power switch to my "control table".
I figured when I bought that it used a soldered on SPST pushbutton switch, but when I got the projector and disassembled it, it had some kind of onboard switch (which I will have to post a pic of becasue its really hard to explain)
Any help would be appreciated
Thanks!
Oh, I almost forgot, It is so old I cannot find a remote for it, so thats not an option.
Jan 23, 2010. 7:22 PMRe-design says:
Yes you are exactly right.  If that is indeed the power switch location if you solder a monentary contact switch to either side of the pcb contacts you should be able to extend the switch to any reasonable length.
Jan 24, 2010. 5:47 PMseandogue says:
Yes. those interleaved pads use a  conductive-foam dot applied to thre underneath of the finger contact to complete the circuit.
Since we can't really say how far away the useable cable might be from a remote switch or how far away the circuit itself will reliably function when replacing its designed actuator with a remote switch, , it might be best to use a small solid-state relay (SSR) to complete the circuit *as close as possible to the contacts, then use a cabled switch connected to trip the SSR, rather than attempting to complete the circuit from afar directly.
Jan 24, 2010. 12:30 AMJayefuu says:
I had a similar problem in this instructable, I did as Re-design suggests and soldered my switch to the contacts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
