How to fix an access file?
I am looking for a way to fix an Access file when open it advises caused a serious error the last time it was opened and then get the file needs repaired or isn't a database file office locks up when trying to repair. I believe the that when copying the file to a jump drive for back up it did not release the record locking information when complete and pulled the jump drive from the computer.
Bennettsumm2 years ago
To resolve the above error and access the data, you will need to install the latest service pack of Windows. However, to repair the already corrupted Accounts database, you will need to use an inbuilt repair utility named “Compact and Repair.” The repair application is fully competent to repair the corrupted Access database in most of the scenarios. However, if the utility is unable to repair the Accounts database and you still encounter the same error message, then you will need to use advanced Access Recovery software. These access repair applications use effective scanning algorithms to scan and repair the corrupted database.
For more: https://getsatisfaction.com/scifihifi/topics/corrupt-msmmmob-mdb-file-msn8q9wbal9gu?rfm=1&topic_submit=true
SheltonRodn2 years ago
Resolution:
To resolve the above error and access the data, you will need to install the latest service pack of Windows Vista. However, to repair the already corrupted Accounts database, you will need to use an inbuilt repair utility named “Compact and Repair.” The repair application is fully competent to repair the corrupted Access database in most of the scenarios. However, if the utility is unable to repair the Accounts database and you still encounter the same error message, then you will need to use advanced Access Recovery software. These access repair applications use effective scanning algorithms to scan and repair the corrupted database.
Stellar Phoenix Access Recovery is a reliable Access Repair utility. It can restore and Repair Access database objects including tables, queries, forms, reports, macros and modules. With highly graphical user interface, the utility supports Microsoft Access 2007, 2003, 2002 (XP) and 2000. It supports Windows Vista, XP, 2003, 2000 and NT.
Or:
Recovery ToolBox for Access is used for recovering data from corrupted database files in the Microsoft Access *.mdb, *.accdb format.
For more information:https://recoverytoolbox.com/repair_access.html
Also look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1038-new-environment-access-2010-compact-and-repair-of-any-accdb-file-suddenly-fails
JackW391 year ago
Reasons of MDB
Corruption & repair MDB file with Access Recovery Tool
It is difficult to recognize what exactly has caused the
corruption. However, there are some common corruption reasons that damage the
file integrity of the Access database.
  • When copying or
    transferring of the file is done incorrectly by your system, there are
    chances of the corruption in file. It can occur while downloading the file
    from network or copying it from any other system.
  • If the system hard
    disk where the Access database is saved has bad sectors, and the file is
    mounted on these damaged sectors, there are chances of file being
    corrupted. In such case, only few part of the MDB file is readable.
  • Virus attack on the
    system where the file is saved is another reason that can cause corruption
    in the file. Infected system can infect all files stored on the same
    system and hence a system must be protected against all such external
    malware programs.
ScottieW12 years ago
You can try to use third party Access file recovery program to recover your lost and corrupted data from .mdb files. For more details about this software:- http://www.mannatsoftware.com/stellar-phoenix-access-recovery.html
KennyC82 years ago
Access File Recovery is an efficient utility to bring all the corrupt or inaccessible ACCDB and MDB files back to life and fix all the minor and major database bugs and errors.It is fast solution to repair access database.To find more information visit :-
http://www.recoverfilesdata.com/access-file-recovery-software.html
modestopuck2 years ago
Use Access File Recovery software helps you to recover and repair corrupt MS Access (.MDB or .ACCDB) database file and then recover tables, queries, forms, macros, reports, etc. It also restores permanently deleted data from MDB file of MS Access 2013, 2010, 2007, 2003, 2002, 2000 on your latest Windows 8.1 PC & all below Windows version like as Win8, Win7, Vista, 2003 and XP.
Download now: http://www.filesrecoverytool.com/access-file-recovery.html
Kernel for Access Recovery tool performs an effective and reliable recovery from corrupt MS Access database file in a very quick time. It can recover data from both ACCDB and MDB database files of MS Access. After a complete scanning process, it recovers all objects of MS access file like tables, data, queries, indexes and relations. The preview of recovered data can be seen in preview pane before the actual recover and recovered data can be saved in new database at user-defined location. Find more:- http://www.accessrepair.recoveryfiles.org/
If your access database file has been corrupted and you are not able to access it, then I recommend to use 3rd-party access database recovery software because it will help you to repair and recover corrupt database file. I have great experience with this tool and used this software many times. Read more: http://www.repairaccessdatabase.com/
