How to get data from a load sensor through bluetooth module on an Android App/Arduino?
I am creating a mobile android application which gets data from a load sensor connected to HC-06 Bluetooth module and sends the data to a mobile application. The mobile app has two activities one for listing the bluetooth devices available and the other is the main activity to get data from the load sensor. I have managed to connect/pair with the Bluetooth module but I am unable to get data from it. The main activity consists of a button 'btnScan' that will get the data, and a text field to display the data.
Can someone please help?
Here is the MainActivity File
package com.uniproj.senseplate;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.UUID;
import android.app.Activity;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.os.Bundle;
import android.os.Handler;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.TextView;
import android.widget.Toast;
public class MainActivity extends Activity {
  Button btnscan;
  TextView txtArduino, txtString, txtStringLength, calorie;
  Handler bluetoothIn;
  final int handlerState = 0;             //used to identify handler message
  private BluetoothAdapter btAdapter = null;
  private BluetoothSocket btSocket; //= null;
  private StringBuilder recDataString = new StringBuilder();
  private ConnectedThread mConnectedThread;
  // SPP UUID service - this should work for most devices
  private static final UUID BTMODULEUUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
  // String for MAC address
  private static String address;
@Override
  public void onCreate(Bundle savedInstanceState) {
    super.onCreate(savedInstanceState);
    setContentView(R.layout.activity_main);
    //Link the buttons and textViews to respective views
    btnscan = (Button) findViewById(R.id.scanBtn);
    txtString = (TextView) findViewById(R.id.txtString);
    txtStringLength = (TextView) findViewById(R.id.testView1);
    calorie = (TextView) findViewById(R.id.sensorView1);
    bluetoothIn = new Handler() {
        public void handleMessage(android.os.Message msg) {
            if (msg.what == handlerState) {          //if message is what we want
             String readMessage = (String) msg.obj;        // msg.arg1 = bytes from connect thread
                recDataString.append(readMessage);              //keep appending to string until ~
                int endOfLineIndex = recDataString.indexOf("~");                    // determine the end-of-line
                if (endOfLineIndex > 0) {                                           // make sure there data before ~
                    String dataInPrint = recDataString.substring(0, endOfLineIndex);    // extract string
                    txtString.setText("Data Received = " + dataInPrint);
                    int dataLength = dataInPrint.length();       //get length of data received
                    txtStringLength.setText("String Length = " + String.valueOf(dataLength));
                    if (recDataString.charAt(0) == '#')        //if it starts with # we know it is what we are looking for
                     //get sensor value from string between indices 1-5
                     String weight = recDataString.substring(1, 5);
                     //update the textviews with sensor values
                     calorie.setText(weight + "kg");
                    recDataString.delete(0, recDataString.length());      //clear all string data
                   // strIncom =" ";
                    dataInPrint = " ";
    btAdapter = BluetoothAdapter.getDefaultAdapter();       // get Bluetooth adapter
    checkBTState();
  // Set up onClick listeners for button to scan for data
    btnscan.setOnClickListener(new OnClickListener() {
      public void onClick(View v) {
        mConnectedThread.read("1");
  private BluetoothSocket createBluetoothSocket(BluetoothDevice device) throws IOException {
      return  device.createRfcommSocketToServiceRecord(BTMODULEUUID);
      //creates secure outgoing connecetion with BT device using UUID
  @Override
  public void onResume() {
    super.onResume();
    //Get MAC address from DeviceListActivity via intent
    Intent intent = getIntent();
    //Get the MAC address from the DeviceListActivty via EXTRA
    address = intent.getStringExtra(DeviceListActivity.EXTRA_DEVICE_ADDRESS);
    //create device and set the MAC address
    BluetoothDevice device = btAdapter.getRemoteDevice(address);
    try {
        btSocket = createBluetoothSocket(device);
    } catch (IOException e) {
     Toast.makeText(getBaseContext(), "Socket creation failed", Toast.LENGTH_LONG).show();
    // Establish the Bluetooth socket connection.
    try
      btSocket.connect();
      try
        btSocket.close();
      } catch (IOException e2)
     //insert code to deal with this
    mConnectedThread = new ConnectedThread(btSocket);
    mConnectedThread.start();
    //I send a character when resuming.beginning transmission to check device is connected
    //If it is not an exception will be thrown in the write method and finish() will be called
    //mConnectedThread.write("x");
  @Override
  public void onPause()
    super.onPause();
    try
    //Don't leave Bluetooth sockets open when leaving activity
      btSocket.close();
    } catch (IOException e2) {
//Checks that the Android device Bluetooth is available and prompts to be turned on if off
  private void checkBTState() {
    if(btAdapter==null) {
     Toast.makeText(getBaseContext(), "Device does not support bluetooth", Toast.LENGTH_LONG).show();
    } else {
      if (btAdapter.isEnabled()) {
      } else {
        Intent enableBtIntent = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
        startActivityForResult(enableBtIntent, 1);
  //create new class for connect thread
  private class ConnectedThread extends Thread {
        private final InputStream mmInStream;
        @SuppressWarnings("unused")
  private final OutputStream mmOutStream;
        //creation of the connect thread
        public ConnectedThread(BluetoothSocket socket) {
         btSocket = socket;
            InputStream tmpIn = null;
            OutputStream tmpOut = null;
            try {
             //Create I/O streams for connection
                tmpIn = socket.getInputStream();
                tmpOut = socket.getOutputStream();
            } catch (IOException e) { }
            mmInStream = tmpIn;
            mmOutStream = tmpOut;
        public void run() {
            byte[] buffer = new byte[1024];
            int bytes;
            // Keep looping to listen for received messages
            while (true) {
                try {
                    bytes = mmInStream.read(buffer);
                    bluetoothIn.obtainMessage(handlerState, bytes, -1, buffer).sendToTarget();
                    break;
        //write method
        public void read(String input) {
            byte[] bytes = input.getBytes();//converts entered String into bytes
            try {
                mmInStream.read(bytes);//write bytes over BT connection via outstream
             //if you cannot write, close the application
             Toast.makeText(getBaseContext(), "Connection Failed", Toast.LENGTH_LONG).show();
             finish();
Here is the Arduino file
#include <LiquidCrystal.h>
int led = 13;
int button = 12;
LiquidCrystal lcd(9, 8, 4, 5, 6, 7);
// Pins used for inputs and outputs********************************************************
float sensorValue1;
float containerValue;
char inbyte = 0;
int flag;
const int numReadings = 50;
int readings[numReadings];
int index = 0;
int total = 0;
int average = 0;
void setup()
  pinMode(led, OUTPUT);
  digitalWrite(led, HIGH);
  Serial.begin(9600);
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
      readings[thisReading] = 0;
  lcd.begin(16, 2); //change to 16, 2 for smaller 16x2 screens
  lcd.clear();
  lcd.print("hello, world!");
  delay (1000);
  lcd.clear();
  delay (500);
void loop()
  readSensor2();    //DONE
  printLCD();       //DONE
  return;
sendAndroidValues();
  //when serial values have been received this will be true
  if (Serial.available() > 0)
    inbyte = Serial.read();
    if (inbyte == '0')
      //LED off
      digitalWrite(led, LOW);
    if (inbyte == '1')
      //LED on
  //delay by 2s. Meaning we will be sent values every 2s approx
  //also means that it can take up to 2 seconds to change LED state
  delay(2000);
void readSensor2()
  total = total - readings[index];
  readings[index] = analogRead(A0);
  total = total + readings[index];
  index = index + 1;
  if (index >= numReadings)
     index = 0;
  average = total / numReadings;
   //sensorValue1 = (analogRead(A0) - 330)* i;
   //delay(200);
   Serial.println(average);
   delay(100);
   if( digitalRead(button) == HIGH && flag == 1)
    flag = 0;
    containerValue = 0;
  else if (digitalRead(button) == HIGH && flag != 1)
  flag = 1;                        //when the button is pressed the initially sesnsor
    containerValue = sensorValue1;
    delay(10);
  //Serial.println(digitalRead(button));
   delay (1000);
//sends the values from the sensor over serial to BT module
void sendAndroidValues()
  //puts # before the values so our app knows what to do with the data
Serial.print('#');
  //for loop cycles through 4 sensors and sends values via serial
  Serial.print(sensorValue1);
  Serial.print('+');
    //technically not needed but I prefer to break up data values
    //so they are easier to see when debugging
Serial.print('~'); //used as an end of transmission character - used in app for string length
Serial.println();
delay(5000);        //added a delay to eliminate missed transmissions
void printLCD()
  lcd.setCursor(4, 0);
  lcd.print("   GRAMS    ");
  lcd.setCursor(4, 1);
  lcd.print(sensorValue1);
thassett272 years ago
I need an app like this for my load sensor!
