How to get rid of decimals or add them?
So here's my code.
void loop()
  int pot = analogRead(A0);
  float xval = pot * (10.0 / 1023.0);
  Serial.println(xval);
When I open up serial monitor, I get a number (1-10 depending on my potentiometer) and two decimals. How do I make go in whole number increments? 1, 2, 3, etc? Can you show me the code and explain it?
Also, here's another example
centimeters = (xval * 2.54);
Serial.print(centimeters);
In this example, I only get a whole number. Can somebody show me some code to make it show decimals? Explain some code?
Thanks!
bwrussell4 years ago
xval is a float data type which has a floating decimal point. If you want whole values only you need to use and int type.
In the second version you probably initiated xval as an int.
HavocRC (author)  bwrussell4 years ago
Oh bwrussel thanks so much! It just hit me!
So if I type in
float xval = ... then it will be a decimal
If I type in
int xval = . . . then it will be a whole number.
And yes, in my other project, I did put initiate them in the beginning of the sketch. Thank you so much!
Use the "printf" statement to adjust the format, and "ceil" and "floor" to clip the number to an integer.
