loading
How to light up an LED underwater?
Our problem is how to make an LED light up underwater (We planned to place an LED in a jar full with water as a part of our science experiment. And also, we'd like to add an on and off button for it.) Is it possible?
mrmerino4 years ago
Connect it to current under water.
quatch4 years ago
For a longer run, Seal the LED and wires in epoxy (two part five minute kind), or use the heatshrink that comes with a heat-melting glue liner.
You can also put it in a ziplock bag.
For your water, make sure it is really clean, if your tap water is hard (if it has a mineral taste), it'll conduct faster.
If you do soldering, make sure you give the parts a good scrub, as the flux and such will dissolve and increase conductivity.
quatch quatch4 years ago
Also, have a look at the related instructables on the right hand bar. Looks like good suggestions
Kiteman4 years ago
Yes.
For short periods, an LED will work fine on a button cell without any protection.
For longer term protection, just put it all in a plastic bag, and squash out all the air.
+1
Water, particularly distilled water does not conduct - so long as the metal does not corrode, which shouldn't happen in distilled water also.
