How to make Joule Thief with Multiple LED and maintaining its brightness.
I know how to build Joule Thief
I have:
-NPN 2N3904, 2N2222A, 2N4401 Transistors
-Resistor what I have now 1K, 560, 100..
-Toroid 12 turns and 20 turns
-LEDs!
-Batteries!
Can anyone tell me what to do to run at least 10 LEDs with good or full brightness?
13
answers
Answer it!
You need to boost up to 120V to drive 100 LEDs !
There are better switchers that will start on 1.5V.
Name on youtube is the same as on here if interested.
Steve
Steve
One approach is using Adafruit's Mintyboost 3. NOTE: the Mintyboost will work better with higher input voltages, but it will boost as low as 1V input to 5v output. (How many LEDs you'll be able to drive is a function of how much power can be pulled from your batteries... you can figure that out).
Another approach is Riad Wahby's "inara" circuit:
http://web.jfet.org/ignignokt/
NOTE this design uses ONE 9V battery, and a pretty damn cool 555 circuit to drive 50 LEDs with minimal use of resistors (read the article to understand why that's a good thing). I've looked high and low for other (similar) 555 circuits for driving many LEDs, without any luck (all the 555 circuits I see use the 555 to blink. Blink is gaudy).
I'm looking to do something similar as you ask, but honestly, I wouldn't attempt this on less than 2AA (and most likely I'll use a 9V, or 4 rechargeable AA in sieries for 4.8V fully charged)
The reason you see "LED throwies" work with 1 small battery is because those coin cell batteries are actually 3V.
L
Joule Thief Light Box
http://www.youtube.com/watch?v=sFpzkyP6DCU&feature=related
Joule Thief..
http://www.youtube.com/watch?v=flbfxAHC7-c
19 LEDs joule thief
http://www.youtube.com/watch?v=Hc2B2rzthoA
Radiant joule Thief
http://www.youtube.com/watch?v=C9ZFKDSxFTE&feature=related
I cant find about Joule Thief with Secondary here..
Not convincing. Looks like he's using a different circuit than a Joule thief, because there are a lot more components on the circuit board.
Third video.
Those LEDs are barely on at all.
Look for boosting switch mode power supplies for some ideas.
Steve
