loading
How to make a TDA2003 10W amplifier give less than it's rated output?
I need to power a single 4w speaker, but can't get an amp for it, so I need to use the tda2003. Should I decrease the circuits voltage? Or is it not possible?
Just turn the volume down on the input. If you put a resistor in series with a volume control, you can set an absolute maximum volume for the output.
DangerousTim (author)  steveastrouk2 years ago
Do you think it will compromise on quality of sound?
Why should it ?
Just asking...Thanks!!! :D
Just asking you the question back, so you can think why it might make a difference: It won't unless you turned the supply voltage down so low that the chip wouldn't work properly driving the demanded volume into the speaker.
+1
Why do you need to use a TDA2003? Why not use an LM2877?
http://www.ti.com/lit/ds/symlink/lm2877.pdf
