How to make a cigarette smoke detector
I have searched for a cigarette smoke detector circuit. But  can't find one. I need it for my research project.. Pls. help me.thanks! :)
vijayP102 years ago
what are component need to make a cigarette smoke detector for car.. please help me.. thank you..
iceng5 years ago
A low cost pulsed laser that draws air through the the beam with an LDR behind the laser feeding a simple AC amplifier will detect smoke particles and if you have it dust...
A
iceng iceng5 years ago
Detail smoke sensor pics 4 U...
Bot1398 iceng5 years ago
The cigarette smoke contains carbon monoxide so you will need a carbon monoxide sensor.You can can buy it from sparkfun.com.Also checkout the wiring example.Experiment with the sensor get the readings using a arduino or any microcontroller and make one yourself
Bot13985 years ago
flxforce5 years ago
You want to make yourself ? It' s difficult ,the plastic and many others kinds of parts.
rickharris6 years ago
The airlines use normal smoke detectors which use the ionisation properties of smoke to set off the detector.
I thought the blocked a current of alpha-particles: Americium 241
L
Could be
orksecurity6 years ago
The question is, how dilute can the smoke you want to detect be?
If sufficiently dense to be seen, the old optical detector approach would work.
If less dense, a commercial smoke detector may be your best best.
If _very_ thin -- if at a level which wouldn't set off a fire-safety smoke detector.-- you're into lab equipment with costs to match.
Kryptonite6 years ago
Smoke detectors are very hard to make as they normally contain radioactive materials, which are not really safe to handle. Cigarette smoke sets off standard smoke alarms, which should help you with your project.
lemonie6 years ago
As different to any other kind of smoke?
L
I am guessing you are looking for some kind of machine olfaction,
http://en.wikipedia.org/wiki/Machine_olfaction
or electronic nose
http://en.wikipedia.org/wiki/Electronic_nose
I mean rather than just an old school smoke detector, i.e. one for detecting the presence of smoke, as an indicator for fire.
http://en.wikipedia.org/wiki/Smoke_detector
