How to make a giant Magna Doodle to use as a white board?
 I want to go about making a giant Magna Doodle to use as a white board in my home office. It would help cut down on the number of pens I use as well as that awful ink smell. Overall, more better for the environment and hopefully for my budget. Any ideas on how you would go about doing this?
Dec 6, 2010. 6:29 PMpbq says:
Hey-- cool idea! The magna doodle board itself is just a millimeter or so of honeycomb spacer filled with milky fluid and iron filings in each space-- they are then laminated between two tough plastic sheets. You could buy a "lot" of them on eBay, remove them from the frames and glue them to a whiteboard. There are some tricks-- you need to be able to swipe the back of the board with a magnetic wand. Also, you just can't puncture them otherwise they dry out quickly. Be sure to use low power ceramic magnets as common "rare earth" magnets will actually cloud the screen-- almost like the front plastic is magnetized and you can't really erase it any more.
Good luck!
Jan 5, 2010. 5:53 PMorksecurity says:
You could always switch to blackboard. No smell, but some dust and occasional screeching sounds.
Jan 4, 2010. 11:03 AMlemonie says:
The resolution on MagnaDoodle isn't that good, and they can end up looking a bit grey. But, how about buying a lot, extracting the panels and making a composite board?
L
Jan 4, 2010. 5:07 AMfrollard says:
Simply because of the chemistry involved - unless you found a huge doodle panel, you're kind of of luck...
en.wikipedia.org/wiki/Magnadoodle
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
