3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a laptop LCD monitor connect to another computer as a normal monitor (physically)?
 Hi,
I want to create an overhead LCD monitor projector (from instructables on here). I do not have an LCD monitor to take apart. However, I do have an old laptop monitor that works and would like to use the screen on that.  My problem is, once I take it apart, the cable that connects the monitor will not be compatible with a standard video cable like a regular monitor would be.  Is there any way that I could use this monitor as my overhead projector. Like, is there some sort of converter or thing I could attach to the cable to turn it into a standard monitor that I could connect to a computer's video card.
Thanks for any help,
I've looked around and haven't found anything.
Oct 22, 2010. 8:20 PMThe_3rd says:
Thanks to Niwaka3, check this out!
If you are of the tinkering type, as I assume pretty much all of us are here, I would recommend looking into the link below for a driver/power kit, direct from japan...
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fwww.aitendo.co.jp%2Fproduct%2F1463
It translates from japanese to english, and is close enough to get the idea of what is going on. I'd love to hear your results!
May 18, 2010. 7:01 PMNiwaka3 says:
Aitendo sells LCD controller board to turn LCD into a normal external PC monitor. As the shop site is in Japanese, I may help you if you don't understand Japanese and still want to know more information.  Specify your old laptop LCD part(NOT laptop itself!) (manufacturer, model, screen size, resolution, etc) , then I will check the site for suitable controller board. Please note that you need DC-AC inverter that drives backlight, AC power supply and interface cable.They are available at Aitendo too.
I am not associated with Aitendo at all.
Apr 28, 2010. 2:59 AMTreknology says:
Does the laptop itself work at all? The LCD and control circuitry are hardwired, although there are articles on running LCD logic from parallel printer ports.
If the laptop is functional, just get a USB video input and convert the entire laptop into a projector.
Apr 15, 2010. 11:44 PMlemonie says:
People keep asking this...
The control hardware is on the laptop mainboard, the laptop screen is just the LCD, it's not a plug & play monitor. These are integrated into the whole device and are not really practical to build into standardised monitors.
L
Apr 15, 2010. 4:05 PMgmxx says:
 you can buy a converter, but it will cost more than just buying a new lcd with the controllers built in.
The reason you haven't found anything, is outside of the computer service industries, solutions don't really exist.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
