loading
How to make a photo diode detect light?
Can anyone help me to know how can a photo diode detect a light. What I mean is the light sensing circuit which will close the circuit when it detects light. Please help, I do not know anything about photo diodes.
And one more thing, is there a circuit not using transistors for the light detecting circuit? And what difference would it make if it's forward or reversed biased?
Here is the circuit I made. Please tell me if there is something wrong with it
Picture of How to make a photo diode detect light?
frollard5 years ago
Never run leds in parallel -- each led needs its own current limiting resistor, or minute differences between the different paralleled diodes will cause one to take more current causing a runaway failure.
Use a transistor if you can - they're cheap and easy to calculate.
arunm42 years ago
how can i make a light detecting diode for use a speaker ?
djacox4034 years ago
So for anyone who searches and wants to know, you can use a photodiode as a switch. you need a transistor to attach it to the base of the transistor. and the collector to the pos while the emitter to the neg which will act as a switch for the photodiode. when light hits the diode, the voltage created will forward bias the transistor and current flows through. simple.
nodoubtman5 years ago
is a photo diode an IR led?
thanks!
The 10K resistor ain't going to let more than 0.5mA through it whatever you do, so the LED will never light.
A "photodiode" is NOT a photoswitch - you need a phototransistor, or a transistor and a photodiode to do what you want to do.
lemonie5 years ago
You want the photodiode to "trip" the base of a transistor that is handling the power for the LEDs.
L
rickharris5 years ago
Depends on which picture you mean on my screen there isn't a big yellow box so i don't know can you capture a picture a show us.
Pages of them here
https://www.google.co.uk/search?q=photodiode+light+detector+circuit&hl=en&prmd=imvns&source=lnms&tbm=isch&ei=FQFeT57TEOWg0QWUxNjcDQ&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CDIQ_AUoAQ&biw=1920&bih=960
cc67 (author)  rickharris5 years ago
what is the large yellow rectangle in the first picture??? tnx for the link
