loading
How to make a simple wireless digital communication circuit?
Hey, i want to make a simple wireless digital communication circuit. This is not exactly what i'm going to do, but this is the easiest way to explain it: watch the image below. What should i build inside "box ?(1)" and " box ?(2)", to make the 2 LEDs turn on when i push the button? The first circuit should be like a transmitter and the seconds one a receiver, but i just don't have any idea how to make this simple circuit. I don't really know what frequency it should be at.. What's the easiest to make and works for the longest distance without problems with background radiation?
(I'm sorry if this is a stupid question but i really a noob in hardware development... :p )
Thanks for helping!
Evert
Picture of How to make a simple wireless digital communication circuit?
rickharris3 years ago
For a few $ you can buy just what you want. A lot more reliable and certain to work.
https://www.google.co.uk/#q=Xbee
There are many variations on the Xbee generally intended to operate with low cost microprocessors.
AlphaZ2 rickharris11 months ago
Could something like these cheap ones work without a microprocessor and just fit in those boxes, or is one absolutely required?
rickharris AlphaZ211 months ago
This is an easy question but hard to answer. on balance I would say because you lack experience the easiest way would be to use something like the Xbee and a Picaxe 08M microprocessor. The cost of the Micro will be about $2 (£1:80)
Programming will be easy as their site has examples.
To build something that can drive data into to these units will be as complicated for you as making a radio Tx RX.
http://www.picaxe.com/docs/XBE001.pdf
This is the data sheet to give you some idea.
http://www.picaxe.com/docs/AXE213.pdf
http://www.picaxe.com/docs/RFA001_TX.pdf
http://www.picaxe.com/docs/RFA001_RX.pdf
As you will see you can drive them with switches but that may not suits what you need.
If your hell bent on making something
https://www.google.co.uk/search?q=433+Mhz+transmit...
lots of 433 circuits here
