How to make an inexpensive Atomic Force Microscope?
I am sorry for my very difficult question. I would like to make an inexpensive Atomic Force Microscope. Can you help me? Thanks.
Your project is possible and has been done by high school students.
http://www.ornl.gov/sci/besd/bsd/nsd/education/afm_high.shtml
http://www.opencircuits.com/Atomic_microscope
If you follow the first link on this page there is a .pdf and . stl  file in the .zip.
In addition, you may be interested in joining the Open Manufacturing Google Group.
http://groups.google.com/group/openmanufacturing/browse_frm/thread/e3ea9182fe618a71/6557015a7926f7e3?lnk=gst&q=afm#6557015a7926f7e3
Good luck, and please post somewhere on your progress.
jolomon2 years ago
A Low Cost DIY Atomic Force Microscope/低價DIY原子力顯微鏡 by whoand
https://www.instructables.com/id/A-Low-Cost-Atomic-Force-Microscope-%E4%BD%8E%E6%88%90%E6%9C%AC%E5%8E%9F%E5%AD%90%E5%8A%9B%E9%A1%AF%E5%BE%AE%E9%8F%A1/
narcoid8 years ago
Yes, an AFM is versatile and can be used under vacuum or atmospheric conditions. Clearly the latter is preferable when studying complex biological systems, say. Instructions for building one "cheaply" can be found here. Here cheap means "less than hundreds of thousands of dollars".
http://www.nanowerk.com/spotlight/spotid=2304.php
VPA (author)  narcoid8 years ago
Thank you very much for the useful link!!! I am really grateful to you. Best Regards, VPA
winburleson VPA6 years ago
Hi VPA,
I am a professor at ASU and am very excited by your post and would like to know how your project and quest to look at DNA, RNA, and Proteins is going. Can you email me at winslow.burleson@asu.edu?
Thanks!
Win
Sandisk1duo8 years ago
i don't think so...
VPA (author) 8 years ago
I am looking at surfaces of biological samples or biomolecules as DNA, RNA or proteins so I just need a system without vacuum.
kelseymh8 years ago
I guess the first question is, what do you mean by "inexpensive." Since it's been invented already, the idea behind an AFM is relatively simple. You would need
  • A very good vacuum system
  • A high-precision piezoelectric stage
  • A cantilever with single-atom-pointed tip at the end
The last item is the hard one. It needs to be made using standard chip-fabrication techniques, so that the tip actually comes to a point with just one atom at the end.
Because those fabrication technique have a high economy of scale (making one is horrendously expensive, making 10,000 is just expensive), it is almost certain that you can buy a working AFM for less than you can make one (unless you happen to have a chip foundry in your garage).
VPA (author)  kelseymh8 years ago
You are right but I think that Atomic Force Microscope don't need a vacuum system.
kelseymh VPA8 years ago
I suppose it depends on what you want to measure. If you want to do clean crystal planes, without having adsorbed gas interfering, then a vacuum system could be useful. If you're looking at surfaces where atmospheric adsorption is irrelevent, you're quite right.
